Hello
What do you use to clean up your acryl finish/airbrush and what pressure do you use for the airbrush application on dye and finish...??
The holsters look very good, real pro work!!!
I used airbrush on shirts abt 25 years ago....now it finally dawns on me its the way to go on leather finish!
Greetings
James
http://www.elfwood.com/~alien883
First it is just leather....then it is what-ever I can dream off...
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Jimbob - I just use hot, soapy water immediately after I'm finished using the air-brush. So far that has worked just fine.
I use about 40-42 psi when spraying the acrylic finish, and around 30-35 psi when using dye. I only use the air-brush to apply a final top-coat for both the dye and finish. I prefer to dip the holsters for the main application of both dye and acrylic finish.
