Members azrider Posted August 31, 2009 Members Report Posted August 31, 2009 I was cleaning out a box this weekend, and I found a key chain thing I had made for my Grandfather as part of my Leatherworking merit badge about 25 years ago. It had hung in an outdoor shed in Phoenix, AZ for at least 20 years, so the leather is very dry, and the lacing is dryrotted. Right now, I am afraid to even open the snap because the leather is so dry. What conditioner should I use on this? I would like to re lace it, and keep it around. Quote
Contributing Member UKRay Posted August 31, 2009 Contributing Member Report Posted August 31, 2009 I was cleaning out a box this weekend, and I found a key chain thing I had made for my Grandfather as part of my Leatherworking merit badge about 25 years ago. It had hung in an outdoor shed in Phoenix, AZ for at least 20 years, so the leather is very dry, and the lacing is dryrotted. Right now, I am afraid to even open the snap because the leather is so dry. What conditioner should I use on this? I would like to re lace it, and keep it around. The easy way: If it were mine - and because it is a tiny thing, I'd fill a container with Lexol and let it soak for a couple of weeks. Just check it now and again to see how it is getting on... Apparently Lexol replaces lost oils and fats so I guess it would work pretty well in this situation. When the leather has recovered sufficiently, just give it a couple of coats of Skidmore's beeswax Leather Restoration Cream to seal it up. Ray Quote
Members azrider Posted August 31, 2009 Author Members Report Posted August 31, 2009 Thanks, Ray. I will try the Lexol. My main worry is that the finish won't let the Lexol into the inside. I have no idea what the finish is, but it is very plastic like and stiff. I will put some pictures up when I get it done. Quote
Contributing Member UKRay Posted September 1, 2009 Contributing Member Report Posted September 1, 2009 My guess is that if the 'goodness' got out, the Lexol can get in... LOL Ray Quote
Members Windom Leather Posted September 1, 2009 Members Report Posted September 1, 2009 Another proicy you could use is Dr Jacksons hide rejuvenator. I'm currently restoring a pair of m/c saddle bags that are very dry and that was recommended to me. I haven't had a chance to try it yet but I hear it works good. Hope this helps and lookin forward to seeing some pics of it when you get it done. How about some before and afters? Quote
Members azrider Posted September 2, 2009 Author Members Report Posted September 2, 2009 I took some pictures of it, and took the lacing out. The leather is in worse shape than I thought. The lacing just turned to dust when I pulled it. I was afraid to try and take the key ring out. Both pieces are currently in a ziplock that has been filled up with Lexol. I will check it again next week. Quote
