Members chouinardragon Posted August 31, 2009 Members Report Posted August 31, 2009 Hi guys, I'm about to buy some sewing machines to make backpack which has leather bottom and patches,just like the old the North Face teardrop day pack. I checked the leather patch of my old the North Face day back and found they are twin stitches and there are 10 stitches per inch. But there're only 8 stitches per inch of the leather bottom. Does it mean that I need 2 leather sewing machine? (My old the North Face teardrop day pack are made from nylon/rip-stop and 3mm leather) What kind of sewing machines will you command on making the leather bottom and patches of backpack? Also,does anyone who ever works for outdoor gear company? I would like to know what kind of machines are needed to make a teardrop day pack,especially cylinder sewing machine is needed or not. Thank you guys! Chouinardragon Quote
Contributing Member barra Posted August 31, 2009 Contributing Member Report Posted August 31, 2009 Hi guys, I'm about to buy some sewing machines to make backpack which has leather bottom and patches,just like the old the North Face teardrop day pack. I checked the leather patch of my old the North Face day back and found they are twin stitches and there are 10 stitches per inch. But there're only 8 stitches per inch of the leather bottom. Does it mean that I need 2 leather sewing machine? (My old the North Face teardrop day pack are made from nylon/rip-stop and 3mm leather) What kind of sewing machines will you command on making the leather bottom and patches of backpack? Also,does anyone who ever works for outdoor gear company? I would like to know what kind of machines are needed to make a teardrop day pack,especially cylinder sewing machine is needed or not. Thank you guys! I make similar gear at work. We run Pfaff 1245's and they will do all you need to make packs like that and then some. Barra Chouinardragon Quote "If You're not behind the Troops, please feel free to stand in front of them"
Cobra Steve Posted August 31, 2009 Report Posted August 31, 2009 Hi Chouinardragon, Barra is right, however, you mentioned in your post something about 2 rows of stitches. This is normally done with a double needle walking foot machine. Sometimes you can sew 1 row and then the next, but you better be pretty good at sewing straight or it will not look professional. They also use a double needle for strength. You can change the stitch length on any machine. Thanks, Steve Quote Thank You Steve Tayrien Leather Machine Co., Inc. 2141 E. Philadelphia St. Unit "U" Ontario, California 91761 1-866-962-9880 http://www.leathermachineco.com cobra@leathermachineco.com
Members chouinardragon Posted September 1, 2009 Author Members Report Posted September 1, 2009 Thanks a lot guys,it really helps a lot. To Cobra: What kind of double needle walking foot machine will you recommend? To Barra: I checked the Pfaff 1245's and found there're some series of it. Which Pfaff 1245 series would fit my needs? Making a the North Face day pack that I attached needs a cylinder machine? Except single and double needle walking foot machines,what else should I get? Singer 269W-1208 bar tacker or Singer 269W box cross pattern tacker? Any others? Thanks Chouinardragon Quote
Members chouinardragon Posted September 1, 2009 Author Members Report Posted September 1, 2009 Hi Chouinardragon, Barra is right, however, you mentioned in your post something about 2 rows of stitches. This is normally done with a double needle walking foot machine. Sometimes you can sew 1 row and then the next, but you better be pretty good at sewing straight or it will not look professional. They also use a double needle for strength. You can change the stitch length on any machine. Thanks, Steve Hi Steve, I think there's a misunderstanding of the 2 rows of stitches. What I meant is there're 2 threads of each stitch of the North Face attachment patch. Please check the attached file. Do they stitch it twice or what kind of machine they use? Thanks! Chouinardragon Quote
Cobra Steve Posted September 1, 2009 Report Posted September 1, 2009 Hi Steve, I think there's a misunderstanding of the 2 rows of stitches. What I meant is there're 2 threads of each stitch of the North Face attachment patch. Please check the attached file. Do they stitch it twice or what kind of machine they use? Thanks! Chouinardragon Hi, after looking at the photo, it looks to me like it was not sewn twice(on top of each other), because that would be almost impossible to do, especially at the corners. It was probably done on a machine that is capable of sewing with a heavier thread. The thread looks to be a 207 or 277. You could use 207 on top and 138 in the bobbin. Make sure that the machine that you buy, has the capabilities to handle this combination. Thanks, Steve Quote Thank You Steve Tayrien Leather Machine Co., Inc. 2141 E. Philadelphia St. Unit "U" Ontario, California 91761 1-866-962-9880 http://www.leathermachineco.com cobra@leathermachineco.com
Contributing Member barra Posted September 1, 2009 Contributing Member Report Posted September 1, 2009 Thanks a lot guys,it really helps a lot. To Cobra: What kind of double needle walking foot machine will you recommend? To Barra: I checked the Pfaff 1245's and found there're some series of it. Which Pfaff 1245 series would fit my needs? Making a the North Face day pack that I attached needs a cylinder machine? Except single and double needle walking foot machines,what else should I get? Singer 269W-1208 bar tacker or Singer 269W box cross pattern tacker? Any others? Thanks Chouinardragon I don't see a need for a box tacker. Your box or gate stich pattern can just as easily be formed manually on something like a 1245. I had a little animation on the sequence of forming a gate stitch that I will see if I can dig up. A bar tacker may be handy but I don't see as essential. Maybe a machine you can add at a later date unless money is not an issue. Barra Quote "If You're not behind the Troops, please feel free to stand in front of them"
Members chouinardragon Posted September 2, 2009 Author Members Report Posted September 2, 2009 I don't see a need for a box tacker. Your box or gate stich pattern can just as easily be formed manually on something like a 1245. I had a little animation on the sequence of forming a gate stitch that I will see if I can dig up. A bar tacker may be handy but I don't see as essential. Maybe a machine you can add at a later date unless money is not an issue. Barra Hi Barra Do you think that Pfaff 1245 has the capabilities of threading size 207 thread on top and size 138 on the bobbin? By the way,I saw a Pfaff 1245 on ebay with servo motor,sells for $900. Is it a fair price? Thanks! Chouinardragon Quote
Contributing Member barra Posted September 2, 2009 Contributing Member Report Posted September 2, 2009 (edited) $900 sounds dirt cheap, why I am asking myself. As for threads. it will easily take 207 top thread and 138 Bobbin thread. you would then use say about a size 160 needle. While not the best pic, this bag was all done on a Pfaff 1245 Barra Edited September 2, 2009 by barra Quote "If You're not behind the Troops, please feel free to stand in front of them"
Members chouinardragon Posted September 2, 2009 Author Members Report Posted September 2, 2009 $900 sounds dirt cheap, why I am asking myself. As for threads. it will easily take 207 top thread and 138 Bobbin thread. you would then use say about a size 160 needle. While not the best pic, this bag was all done on a Pfaff 1245 Barra Hi Barra, Wow~ You're really good at making bags. Is your Pfaff 1245 equipped with servo motor? I just downloaded a manual of Pfaff 1245 which shows that there're some subclasses of 1245. Which 1245 subclass you recommend that would fit my needs? Or it doesn't make any difference? Thanks and sorry for taking you so much time to answer my questions. Chouinard Quote
