Members hivemind Posted September 1, 2009 Members Report Posted September 1, 2009 Just a quick shot of some arms I'm working on for myself out of 16 oz leather. They're not nearly done, but you can get an idea so far: The elbows are together with Chicago screws for now (they're really useful for testing things out), but the final product will be done with peened copper rivets. I'll lace the vambrace and put a single strap on the rerebrace. Gonna dye it a dark red with black. You can see the rest of the other arm cut out and shaped on the table behind. Quote
Members jana Posted September 1, 2009 Members Report Posted September 1, 2009 16oz! What did you do to form it? Won't copper rivets stop some of the articulation? Please post pictures when you are done of you modeling them. Quote Jana "A journey of a thousand miles must begin with a single step." - Chinese Proverb
Members hivemind Posted September 1, 2009 Author Members Report Posted September 1, 2009 (edited) The forming is just hot water, I don't do any kind of wax impregnation. I have to be careful when I use the rivets and not draw them tight. Probably also add a washer between the layers of leather. But, even if I do draw them too tight, they'll smooth out eventually - it's leather. What I'm trying to figure out is how to slick the insides of the cutouts on the cross besegews. Bone folder maybe? I dunno... Edited September 1, 2009 by hivemind Quote
Members hivemind Posted September 4, 2009 Author Members Report Posted September 4, 2009 One down, seven to go (arm, leg, leg, torso, shoulder, shoulder, gorget): Quote
Members hivemind Posted September 7, 2009 Author Members Report Posted September 7, 2009 Got both arms done. Quote
Members RuehlLeatherWorks Posted September 11, 2009 Members Report Posted September 11, 2009 Niiiiiiiiice.Time for some matching Spalders! Quote
Members hivemind Posted September 14, 2009 Author Members Report Posted September 14, 2009 I think the gorget is next, because I simply can't keep the arms immobile without attaching them to something higher on my body. Yesterday, I laced them onto my chainmail (I punched two holes right below the point of the rerebrace (upper arm) and ran a lace through them and up through the chain) but the final solution will be to hang them from the gorget. So, gorget next, then legs (need the protection there badly) then pauldrons, then a back-and-breast, then some scaled gauntlets to finish it off. Damn, it's nice to work on something for myself for a change. Quote
Members Peter Ellis Posted September 18, 2009 Members Report Posted September 18, 2009 I think the gorget is next, because I simply can't keep the arms immobile without attaching them to something higher on my body. Yesterday, I laced them onto my chainmail (I punched two holes right below the point of the rerebrace (upper arm) and ran a lace through them and up through the chain) but the final solution will be to hang them from the gorget. So, gorget next, then legs (need the protection there badly) then pauldrons, then a back-and-breast, then some scaled gauntlets to finish it off. Damn, it's nice to work on something for myself for a change. Strong recommendation against attaching those arms to the gorget. Instead, sew a leather patch on your gambeson at the shoulder, punch a pair of holes through the patch before sewing it in place, and run a tie from there through a pair of holes in the top of your rerebrace. Hanging them off the gorget will pull the gorget as your arms move and not provide adequate support for the arm harness. What will you be using this harness for ? Quote Peter Ellis Noble Lion Leather
Members hivemind Posted September 19, 2009 Author Members Report Posted September 19, 2009 It's being used for Dagorhir and LARP combat. You may be right about the gorget, thinking about it more. Tying them to the maille was fine, but I did that at the point of the shoulder, plus the maille's pretty heavy and immobile already. The attachment point to the gorget would be a lot further up my shoulder, and the gorget isn't remotely close to as heavy as a chain hauberk. Can't hurt to try pointing them to the gambeson first. I just don't wanna hand sew anything - I'm lazy like that... Quote
Members RuehlLeatherWorks Posted September 20, 2009 Members Report Posted September 20, 2009 From the ones I've seen, most people attach the rerebrace to the spalder/pauldrons and then the pauldrons attach to the gambeson as mentioned above. It's a good anchor point and provides good mobility. Then the gorget covers the attachment points and collarbone. Quote
