I was thinking about attempting to make some home made leather dye for my holster project I am undertaking. Has anyone had any expierences making dye out of strong coffee reduced? It would seem that brewing strong coffee and then further reducing it on a stove would yeild a useable dye btu wanted to ask before i wasted my time or hosed up my work. Thanks. PEACE
howdy Guys and gals here are some reciepies that ive gotten over the last few months hope these help all that are wondering bout natural dyes
Here's some instructions for some of the old time dyes I'm working with these days:
1) Black: VINEGAR BLACK (aka Vinegaroon - these are original old formulas)
For giving color to the grain of leather there is no blacking that will at all compare with the well known vinegar black. This may be made in various ways. The simplest, and, without doubt, the best, is to procure shavings from an iron turner and cover them with pure cider vinegar; heat up and set aside for a week or two, then heat again and set in a cool place for two weeks; pour off the vinegar, allow it to stand for a few days, and draw off and cork up in bottles. This will keep for a long time, and, while producing a deep black on leather, will not stain the hands.
Another method is to cover iron scraps with sour beer, and allow them to stand for a month or more; then strain off the beer and bottle as before.
A third method is to boil sulphate of iron in vinegar; mix some brewer's yeast with beer and allow it to stand for twenty four hours, then skim off the yeast and add the vinegar.
Instead of iron shavings you can use steel wool. To use the steel wool burn off the oil first - I dip it in acetone and use a propane/blow torch and light it off in an old pan with a lid, just in case you need to put the flame out. Take all precautions and it will work fine. The only problem with steel wool is it often has copper and other metals in the "mix" which can sometimes add a greenish tint.
After the "dye" (actually it's a reagent) dries I then neutralize with a slurry of baking soda and room temp water, about a 1/2 cup baking soda to a quart of water. Then I let the leather dry until just damp and apply a light coat or two of oil (I generally use olive oil, Lexol, Conditioner, or Lexol non-greasy Neats Foot). When the "dye" first dries it may look bluish or grayish at first and sometimes a second coat is needed, but normally the neutralizing and oil will turn it black.
2) Brown: I use black walnut hulls (If they are not available locally - the fresh green hulls are best - you can buy them dried on line from various vendors - to find a vendor search for walnut dye, etc.) Put a pound or so of the crushed hulls in an old stocking and place in a pan of distilled water so that the water covers the walnut hulls about an inch. Cover it and simmer at a low boil for several hours and then let cool overnight - keep an eye on the water level. The next day boil again and let cool overnight. Again watch that the water level does not get too low, but you do want it to get fairly thick. Once it's cool drain off the liquid be sure to squeeze all of the liquid out of the bundled walnut hulls. Save the walnut hulls - hang them up to dry and you can use them a couple of times more. The liquid will go bad so either keep it frozen or add 3/4 of a cup of rubbing alcohol to a quart of the dye. This is the dye I used on the Slim Jim in the DVD. It will come out anywhere from a light brown/gray to a dark grayish brown before oiling (I use light olive oil a lot for oiling and then set it in the sun to darken) - the color will depend on the leather - every piece is different, how long you let it soak, and how strong the dye is.
I always do a test on a scrap of every new hide, I use only American tanned hides - mostly from Wickett & Craig. You can also mix the two dyes, which gave me a rusty/black on the pieces shown below. I used a 60/40 mix of walnut to vinegaroon on the belt and a 75/25 on the holster:
MAKING COFFEE & NUT DYES = HOW TOO's
Just so this doesn't get more complicated than it is.
#1 , DARK ROAST COFFEE 1# CAN OR MORE, it's up to you, I make about 10 to 12 QT. with this, and I use a 20 qt. pot with lid, if you have a 20 qt. iron pot with lid , use it if you can lift it...
#2, use some IRON, SHAVINGS, IRON NAILS NOT PLATED OR GALVANIZED, JUST SIMPLE IRON NAILS, a lot of your finish nails are iron, if it will rust, or will stick to a magnet it has IRON IN IT, but you want to clean off any oil or grease it may have on it before you put it in your pot, steel wool is OK but you have to burn the oil out of it, which is a pain, LOTS OF SMOKE. WITHOUT IRON AS A MORDANT, YOU CAN'T ACHIEVE MUCH COLOR, IF AT ALL......( IMHO ) especially if you want a deeper darker color.
#3 with 10 to 12 QT. of water in your pot, bring it to a boil, then turn the flame down to a slow simmer, and let cook with the LID ON, for about three hours or so, let cool over night, and then do the same thing again the next day, if you want to cook it three or four days go ahead and do so, just make sure you keep your water up and don't let it boil dry, and leave the lid on through the whole process.
#4 AFTER THE COFFEE DYE HAS COOLED, you can pour the whole works, COFFEE/COFFEE GRINDS/IRON/DYE, in a thick plastic container, for what ever size you need for what you're going to dye, ( small and deep for holsters ) ( large and flat for belts )
#5 PUT YOUR LEATHER in the container, and leave it SUBMERGED for 24 hours or more if you want.
#6 REMOVE YOUR LEATHER from the container, if it is a holster , you want to do your wet molding now, and let dry for 24 HOURS. if it is a belt, lay it out straight, so it will dry the way you want it.
#7 APPLY LEXOIL CONDITIONER, both sides of leather and let dry for a couple hours.
#8 APPLY NEATSFOOT OIL, a couple coats should do, but you can vary the color with the amount of oil you put on, LET DRY OVER NIGHT.
#9 THE FINISH is up to you, you can leave it the way it is now, or you can do like I did by using Gum Thraecanth at 40/60% water, and Bag Kote at 40/60% water, I use a spray bottle to apply this, just apply as you want and rub in, and when it looks the way you want , STOP... YOU can also finish your burnishing at this time.
#10 IF YOU WANT AN ANTIQUE LOOKING holster or belt, you will want to bend and twist your leather, to put some wrinkles in the leather, and give the leather that used look.
#11 AS A FINAL STEP, I apply a coat of Skidmores Leather Cream,
#12 NOW YOU WANT TO STORE YOUR DYE, I put the works in a empty cleaned CAT LITTER container, and I add a 1/2 cup of Rubbing alcohol to every QT. of dye, put the lid on tight and store.
#13 WHEN YOU WANT TO USE IT AGAIN, it will help to pour it all back in the pot and cook it again, the alcohol will burn off real quick, and you will have to add more at the end of your dying work, but this helps activate everything, you could even add more coffee at this time,
#14 JUST A NOTE, your dye should look like OLD MOTOR OIL, a dirty black, the Mexican one loop holster I did was dyed for 24 hours, and you can see the color of the coffee that came out when the leather was oiled, so have fun with this, you can create just about any shade or color you want by testing on scrap leather.
#15 When doing the NUT DYES, Get the nut as they have fallen off the tree, when the hulls are Green, you will get better color out of the Green hulls, you can use the other , but the green works best. you want to remove nuts after cooking and before submerging your leather in the dye, you can hang the nuts up in a stocking and let air dry, or you can freeze them and use them again, also when cooking the nuts, I like to cook them for three days with the cooling in between, and when dyeing I leave my leather work submerged for five days, this longer time allows the color pigment to really get into the leather. Follow up the same as the Coffee dye.
I hope this will make it easier to follow how to make these dyes
