Members Sal Posted October 17, 2009 Members Report Posted October 17, 2009 What is the correct sequence of adding a basket stamp to a project that includes a tooled design---before tooling the design or after tooling the design. Then----how close to the tooled design should the basket stamp be?; And, in what sequence is the backgound added? Quote
Ambassador pete Posted October 17, 2009 Ambassador Report Posted October 17, 2009 I think that we need more information. Is the basket space big or little- what is the pattern-does it surround the basic pattern or is it the focal point-do you plan to have a border or bead separating it from something else- etc. post your pattern if you can pete Quote
Members Sal Posted October 17, 2009 Author Members Report Posted October 17, 2009 I think that we need more information. Is the basket space big or little- what is the pattern-does it surround the basic pattern or is it the focal point-do you plan to have a border or bead separating it from something else- etc. post your pattern if you can pete The basket space on this particular piece is not too big and it will have a border and it will surround the leaf. In general, which comes first?, as I do plan on doing larger pieces where the basket stamp will surround the focal design? Your help is so appreciated. Quote
Ambassador pete Posted October 17, 2009 Ambassador Report Posted October 17, 2009 The basket space on this particular piece is not too big and it will have a border and it will surround the leaf. In general, which comes first?, as I do plan on doing larger pieces where the basket stamp will surround the focal design? Your help is so appreciated. If I were doing this I think that I would lay out and cut the borders first, bevel the borders,do the basket stamp just to the edge, then camo or put a border stamp around it. Then I would check the measurements to make sure that it didn't stretch with that much basket stamping in the middle. (Of course you should tape/glue the piece to a board first.) Just the same, they do stretch sometimes so make sure that your piece is larger than the final size. Hope this helps- and make sure that you show us when it's finished!! pete Quote
