Ok, I was at a local flea market and found this tool. I have no idea what it is, all I know it was cheap (.50 cents) and I may be able to use it in my leather work.
It has "B.O. PAINE CO." stamped in the side. I Googled it but only found an old antique nail cutter for slate roofs.
Any of you folks have an idea?
Troy
look similar to the tool to do the mortar joint s on brick
I'd be inclined to agree. We'd call it a 'pointing' tool in the UK.
Ray
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
one end looks like you could use for a large beader blade. or throw it and see if it comes back!
charlie
Edited by iwannabeacowboy
I'm never to old to learn about all the things life brings along.
It is a masons beaded tuck pointing tool I believe. Something that would be used in stone joints not red brick type possibly.
Edited by TTcustom
I am fifty years old and I have always lived in freedom; let me end my life free; when I am dead let this be said of me: 'He belonged to no school, to no institution, to no academy, least of all to any régime except the régime of liberty.'
"What we need is more cowbell!"
It is called a bead jointer and it is used for making a "beaded" mortar joint between brick or stone masonry. The one end is used to pack and smooth the mortar in the joint and then the side with the grove is used to shape the bead.
This link will show you the different types of mortar joints and the second link shows you the kinds of jointers used.
http://images.google...IFYbzmQeGkKjMCw
http://images.google...pF8azmQe525TRCw
I have a number of jointers that I use for masonry and stone work but I have never tried them with leather work. I don't see why they wouldn't work and in fact I am going to look at more of my tools in a different light now. Thanks for the idea.
Ray
charlie
I had a feeling it was something to do with masonry but wasn't sure. Maybe I could use it to really get in them tight corners...
Thank you ALL for the help!
Troy
