hello everyone
curious,,,,, would anyone mind elaborating on the entire process of how one should go about cleaning leather with this solution?
salutations
REVOLUTION LEATHER
one side fits all
hello everyone
salutations
Crissy:
it's primarily a bleach (as opposed to a cleaner) & helps lighten leather a bit (veg-tan), but it will NOT turn it white, nor will it help a lot with sun-struck leather to a tremendous degree, but it may help even out the contrast somewhat. It does help bleach out some stains. I don't use it a lot, as I feel it's unnecessary for most projects. It may also help remove any surface oils that may screw up dyeing. If you really want to be sure, I'd use the oxalic acid, let it dry & then go over it with deglazer.
As far as application, I would simply wipe with a sponge that's been dipped in it.
russ
I got my technical grade Oxalic acid in the UK from ebay.
Crissy:
russ
thank you this is good "simple" news :)
crissy
Edited by crissy
REVOLUTION LEATHER
one side fits all
  • 1 month later...
OK. I think I found some of this stuff. Can anyone tell me what mixture of Oxalic Acid to Water I should mix?
Acording to the Leatherwork Manual, it states "...mix your own by dissolving about 1 teaspoon of oxalic acid crystals in a pint of warm water and shake well"
Hope that helps.
Hope that helps.
Whats that book called?
I recommend that you look at the following links. It is supposed to be some nasty stuff. I believe it accumulates in the body.
http://www.jtbaker.c...hhtml/o6044.htm
http://www.sciencest...msds/C2193.html
http://www.inchem.or...sc/eics0529.htm
When I was cleaning out my dad's old wood working shop, I found a 5 pound box of the stuff that had never been opened. The label had faded almost to the point of being unreadable but the "store this side up" and "Caution - Corrosive" got my attention. Had I not known about the stuff I probably would have opened the plastic bag within the box to see what it was or just tossed into the nearest garbage can.
Sure if you sniff it or don't take proper precautions. It can be detrimental to your health, so can a bunch of other household products. Oven cleaner comes to mind. Not to mention all the crap we put in our pools to keep them clean, hydrochloric acid, diatomaceous earth (d.e.) (certified to cause cancer), etc...
Key is proper equipement, i.e. gloves, and well-ventalated areas. I don't use it very often, but do use it. But I wouldn't use it without following the directions, the Leatherwork Manual, mentioned above explains that this is an acid, and proper protective equipment is essential, If you chose not to use the equipement, prepare for the consequences.
Ever get dye on your fingers? Do you know that soaks into your skin, and gets into your blood stream? Think that's healthy? I'm not trying to sound condesending or anything, just pointing out that there are plenty of dangerous chemicals in the leatherworking industry. You should know how to properly use them and dispose of them. Sounds like you did the right thing when you found out it was corrosive.
Edited by Rawhide
Marlon
I'll be using rubber gloves next time I use dye :) Thanks Rawhide...
  • 1 month later...
There is no need for using Oxaclic acid. Not only is the stuff hazardous, but it will turn your leather pink or red if it gets put in the sun. Lemon juice does the same thing the acid does, only with no ill effects at all. Put some lemon juice on a sponge and wipe it on your leather. It will take out anything oxalic acid will. Wipe it with a clean wet sponge or cloth to remove any residue when you're done. You may want to do this twice. No need for rubber gloves or any caution of any kind, and you can make lemonade when you're done!
All bad yaks make their way to the freezer.
