Members JeffGC Posted January 19, 2010 Members Report Posted January 19, 2010 Shortly, I will be constructing a IWB holster for a hammerless J-Frame revolver. I am designing it with a retention strap and a thumb break. Most holsters of this type reinforce the tab on the thumb break with some sort of stiff material. What do some of you use for the stiffener? Quote
Lobo Posted January 19, 2010 Report Posted January 19, 2010 Jeff: I will be very interested in seeing your IWB design for a hammerless S&W revolver with a thumb-break retention. These revolvers do not permit the use of traditional thumb-break designs, so yours will draw a lot of attention if it provides positive retention. As for the common means of reinforcing the thumb-break, I use 24-gauge sheet metal. Others use Kydex. And there are pre-fabricated reinforcement tabs offered by a couple of sources. Looking forward to your completed project. Quote Lobo Gun Leather serious equipment for serious business, since 1972 www.lobogunleather.com
Members dickf Posted January 19, 2010 Members Report Posted January 19, 2010 On 1/19/2010 at 12:46 AM, JeffGC said: Shortly, I will be constructing a IWB holster for a hammerless J-Frame revolver. I am designing it with a retention strap and a thumb break. Most holsters of this type reinforce the tab on the thumb break with some sort of stiff material. What do some of you use for the stiffener? Hi Jeff! I personally think that an IWB with thumb break is a liability and not safe. If you're going OWB, then that's a totally different animal. Decent boning along with friction from being inside the pants and the added rigidity of a belt should be plenty of retention. An IWB is a means of concealment, and getting past your cover garment and drawing cleanly and quickly is hard enough - adding a thumb break only complicates things and makes a potential situation even more dangerous. Just my 2 cents. Good luck! Quote US GUNLEATHER www.usgunleather.com twitter.com/usgunleather facebook.com/USGUNLEATHER
Members JeffGC Posted January 20, 2010 Author Members Report Posted January 20, 2010 (edited) Unfortunately, I mis-spoke (or mis-typed). I'm making an OWB holster for the J-Frame. Recently, I made a pancake holster for this revolver (340PD) which works well. I'm a bit concerned about retention in the holster. With autos, there are a lot of features (ejection port, slide release, mag release, etc.) that, when boned, aid in the retention of the weapon in the holster. There isn't much with a revolver. That's why I'm considering redesigning the holster, adding a thumb-break retention strap. If you have any other ideas, they would be greatly appreciated. Edited January 20, 2010 by JeffGC Quote
Contributing Member TwinOaks Posted January 21, 2010 Contributing Member Report Posted January 21, 2010 What I've done with a few revolver holsters is to carry the holster and reinforcement band a little higher on the cylinder/rear shield and make a little bit of a lip there. It isn't as secure as a strap but it helps. When making for a completely shrouded hammer (aka hammerless), there really aren't too many options. Another option is to completely cover the cylinder and hammer (less) portion of the gun with a continuous piece (front of the holster) and extend it to form a strap. Mold the leather to enclose the cylinder when you do this. I'll see if I can find my pattern for this, if not I'll redraw one. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members JeffGC Posted January 21, 2010 Author Members Report Posted January 21, 2010 On 1/21/2010 at 4:49 AM, TwinOaks said: What I've done with a few revolver holsters is to carry the holster and reinforcement band a little higher on the cylinder/rear shield and make a little bit of a lip there. It isn't as secure as a strap but it helps. When making for a completely shrouded hammer (aka hammerless), there really aren't too many options. Another option is to completely cover the cylinder and hammer (less) portion of the gun with a continuous piece (front of the holster) and extend it to form a strap. Mold the leather to enclose the cylinder when you do this. I'll see if I can find my pattern for this, if not I'll redraw one. Mike-Thanks for your suggestions. If you can find the pattern, I'd appreciate it. Quote
Members Tac Posted January 21, 2010 Members Report Posted January 21, 2010 (edited) Another option is to use a style similar to a Bianchi holster for this type of revolver, where the "thumb break" is actually placed over the rear of the trigger guard and snaps behind the gun. The retention strap is then released by the shooter's middle finger during the draw. Here is a link to the Bianchi web site that better illistrates the design. http://www.bianchi-intl.com/product/Prod.php?TxtModelID=55L -Tac Edited January 21, 2010 by Tac Quote -Tac "Well, I guess we did our good deed for the day Mayor"-Wyatt Earp "Tombstone"
Members Bronson Posted January 21, 2010 Members Report Posted January 21, 2010 (edited) On 1/21/2010 at 3:16 PM, Tac said: Another option is to use a style similar to a Bianchi holster for this type of revolver, where the "thumb break" is actually placed over the rear of the trigger guard and snaps behind the gun. The retention strap is then released by the shooter's middle finger during the draw. That's what I did with my Ruger GP-100. I had to go back and shorten the strap since it wasn't tight enough to actually provide any retention. I also added a tension screw just below the end of the crane which helped. Here's the holster before I made the above adjustments. http://www.flickr.co...57606586066759/ If you look at mine you can see that the strap falls a little shy of the junction of grip/trigger guard. I think the closer you can get to this junction the better your retention is going to be. Some forward cant to the gun will also help. Mine is a straight drop holster and if it was tipped forward a little it would've provided a better angle for the strap. Bronson Edited January 21, 2010 by Bronson Quote
Members JeffGC Posted January 21, 2010 Author Members Report Posted January 21, 2010 Bronson - Unfortunately, the Flicker link does not work for me. Quote
Members Bronson Posted January 21, 2010 Members Report Posted January 21, 2010 (edited) On 1/21/2010 at 9:25 PM, JeffGC said: Bronson - Unfortunately, the Flicker link does not work for me. This should fix it http://www.flickr.co...57606586066759/ Bronson Edited January 21, 2010 by Bronson Quote
Members katsass Posted January 22, 2010 Members Report Posted January 22, 2010 (edited) On 1/19/2010 at 12:46 AM, JeffGC said: Shortly, I will be constructing a IWB holster for a hammerless J-Frame revolver. I am designing it with a retention strap and a thumb break. Most holsters of this type reinforce the tab on the thumb break with some sort of stiff material. What do some of you use for the stiffener? Jeff, I have made a number of holsters for J framed Smiths. All have been for off-duty or plain clothes wear by LEO's. None of them have wanted a retention strap and all have been quite satisfied with my simple design for this sort of use. Here's a couple of pics of my latest J frame holster.....left handed in this case. Just something to think about. Mike By the way, all of these are made with two layers of 3/4 oz veg tanned leather, bonded flesh side to flesh side and saddle stitched all around. Edited January 22, 2010 by katsass Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members TTcustom Posted January 22, 2010 Members Report Posted January 22, 2010 I have been using the banding strap material from palletized cargo to reinforce the snap area. Quote I am fifty years old and I have always lived in freedom; let me end my life free; when I am dead let this be said of me: 'He belonged to no school, to no institution, to no academy, least of all to any régime except the régime of liberty.' "What we need is more cowbell!"
Members BOOMSTICKHolsters Posted January 26, 2010 Members Report Posted January 26, 2010 On 1/20/2010 at 8:41 PM, JeffGC said: Unfortunately, I mis-spoke (or mis-typed). I'm making an OWB holster for the J-Frame. Recently, I made a pancake holster for this revolver (340PD) which works well. I'm a bit concerned about retention in the holster. With autos, there are a lot of features (ejection port, slide release, mag release, etc.) that, when boned, aid in the retention of the weapon in the holster. There isn't much with a revolver. That's why I'm considering redesigning the holster, adding a thumb-break retention strap. If you have any other ideas, they would be greatly appreciated. It is actually fairly simple to get good retention with a revolver holster. Just make the holster completely cover the cylinder and bone the leather in above the cylinder a little bit. Just be sure to flare it back out at the mouth so it is easy to insert the pistol without fighting with the holster. Quote
Contributing Member TwinOaks Posted January 28, 2010 Contributing Member Report Posted January 28, 2010 Good news, I found the holster pattern/ drawing. Bad news- it'll be this weekend before I can re-scan it and post it (I'm on the road). Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
