wulfe67 Report post Posted January 23, 2010 I am in need of some Superman logo conchos for a special personalized order. Does anyone know where I can find them or something that I can use in place of a concho. Any help would be greatly appreciated!!! Thanks Quote Share this post Link to post Share on other sites
jakeamon1 Report post Posted January 28, 2010 I am in need of some Superman logo conchos for a special personalized order. Does anyone know where I can find them or something that I can use in place of a concho. Any help would be greatly appreciated!!! Thanks I've made some conchos by using JB Weld, a pendant, and a rapid rivet. I taken metal pendants that are painted and roughed up the backside with a dremel tool so the weld would adhere well. Same with the rivet. Need to use JB with a painted pendant because the heat from soldering will melt the paint. You may be able to find a superman pendant that would work. Good luck. Quote Share this post Link to post Share on other sites
wulfe67 Report post Posted January 28, 2010 I've made some conchos by using JB Weld, a pendant, and a rapid rivet. I taken metal pendants that are painted and roughed up the backside with a dremel tool so the weld would adhere well. Same with the rivet. Need to use JB with a painted pendant because the heat from soldering will melt the paint. You may be able to find a superman pendant that would work. Good luck. Thank you for the tip. I have found some "Lapel Pins" that I will try for now but if that doesn't work I will definitely be on the look out for some pendants Quote Share this post Link to post Share on other sites
savvydreambuilder Report post Posted March 9, 2010 (edited) Another option would be to find a logo that you like and is suitable to be a concho and have it laser cut out of stainless or brass and then braise on chicago screw, or if for a saddle then braise on a saddle screw. If it is too flat, then the laser cut is easily pressed into a dome shape with a fairly simple die. Nicole Edited March 9, 2010 by savvydreambuilder Quote Share this post Link to post Share on other sites
