hi not shore on wot to do next i am a bit stuk ? do i knock back the background or would i knock back the hair any help or abvice plz thanx bob (walletman) :coffeecomp::helpsmilie:
You can do either, to tell the truth. If you tool in the background, the image will stand out from the surface. If you tool in the image, it will be called "Inverted Carving". If you're planning on using acrylic paints with this, inverted carving will give the paint a place to set below the surface and avoid excessive wear.
