ashlyngr
Stitching Holes
I'm getting ready to make my first Knife Sheath. I'm making a sandwich style and not a folded style. My front, welt, and back layers of leather will be approximately 3/4" thick. Has anyone used a dremel drill press or table top drill press with good results?
I haven't attempted to pierce leather that thick with a standard or sewing awl.
Thanks,
ashlyngr
There has been some discussion of placing an awl needle in a drill press without it running- sounds like it'd make a decent arbor press. The dremel press?? Dunno. You will likely find it easier to penetrate the leather, even at that thickness, if you moisten it first. Also, if you set everything up with rubber cement and get your edges right first....you can make a template for the holes and do one layer at a time.
I did the stitching holes for this with a drill press:
~Noah
Thanks,
ashlyngr
Ashley;
I have great luck laying everything out, hand punching, glueing and hand sewing. Takes a little longer but is a great patience builder!!
Jeff
