Hi All
There are some beautiful holsters in Packing Iron that are scratch carved. What tool could I use to do it?? Ive tried using a stitch groover but it dents the surrounding leather!!! Any info gratefully received!
Hi All
Possibly because I haven't seen 'Packing Iron', but I don't know what you mean by 'scratch carved' can you - or anyone else enlighten me?
Ray
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
Packing Iron is my Bible at the moment!!! Scratch carving...incised carving.....not tooled just lines scratched into the leather. I was thinking of an adjustable V groover or something??
Leather Scratch Carving: Primative way of incising a design into the leather. Preceded our modern day swivel knife and tools. The method goes back to Medieval times.
Dull/Scratching Awl/Round Awl - A round cross section, blunted tip. This is not intended to punch a hole in the leather, and therefore should not be sharp. It is meant to mark the leather, or, perhaps, to widen a previously made hole. It is also entirely probable that some form of Marking Scriber, or Scratch Awl was used in the Middle Ages, but I have no solid documentation for it (although the "horn" on the half moon knife might serve such a purpose.
Hope that this helps.
Storm
Please keep in mind that unless I ask for anyones critique I do not want nor require same.
Storm
Most informative, but:
okay, not exactly worthless, but it would make a lot more sense to me!
Ray
Ray Hatley
Okay Ray..here you go!! Simple scratch carving with a stitch groover......horrible to use.....I'll try Storms idea!!!
I use a number 21 exacto blade for that type of work. Cutting in very slightly from both sides.
"Nature is just enough; but men and women must comprehend and accept her suggestions."
Antoinette Brown Blackwell
Ray
Oh Really! Might I suggest the you buy or borrow "Packing Iron" and you will find a wealth of images!
The Book is available on e bay for about £27. Its a fantastic book with pictures of holsters from all the famous makers..well worth buying. In regards to Celtic Maidens idea of using a craft knife....I wouldnt have the patience!!!!
Is it necessary to cut through the surface of the leather for a piece to be 'scratch carved'? Or does the technique perhaps involve scratching away a 'resist' or a dyed surface to reveal the plain leather below?
I ask because much of the decoration on medieval leatherwork was done using a simple creasing tool and a selection of very basic embossing tools which were sometimes made from bone. In the pieces I have seen, lines were generally embossed into the leather rather than cut with a sharp tool. You might find that a simple modelling tool would do this kind of job well enough if it were used on well cased leather - and if a 'cut' isn't essential.
The technique you describe isn't confined to the old West, I have seen similar looking work on both traditional North-African leatherwork (also using very similar hand-cut bone tools) and work from the Indian sub-continent done with hardwood embossing tools.
I believe it is also used as a background technique for some of the early, highly detailed, Moorish leatherwork. Perhaps the influence behind this type of decorative work on gunholsters is Moorish - carried to the New World by the Spanish conquistadors.
I'd be very interested to hear what Chuck Burrows has to say about the history of this technique.
By the way - I thought " Packing Iron" was a film! LOL
Ray
Ray Hatley
