When I have wiped it on, I used a dauber and cut 50/50 with water. I only do that on leather I need to stay clean, especially if I'm doing edging and working with it a while after some portions have been dyed. It helps resist dust staining.
I have not used Bag Kote.
I was told the Angelus brand acrylics are thinner than Resolene but I haven't confirmed it myself.
That sounds good if the Angelus is thinner. As I know if you put it on too thick, it can crack. I'll probably just use a damp sponge and wipe it on with that and let dry. I'll do some test pieces of the Matte and Satin to see if there is a difference. I'm also going to do test pieces of the different Angelus blacks. They have a special black 507 dye that has additional ingredients that allow the dye to penetrate hard and/or difficult leathers. I'm gonna test that as an edge dye since the Fiebings edge dye is too shinny.
