Contributing Member UKRay Posted February 13, 2010 Contributing Member Report Posted February 13, 2010 I have always set cap and stem rivets by womping them with a hammer, but since my eyes have been opened by the good folk of this forum I've mended my ways. I even purchased a rivet setter from Tandy Leather Factory. LOL Now, instead of a dead flat rivet I get a domed top rivet. It looks great but for one thing, I seem to get a little depressed ring around the outside edge of the rivet dome as if the tool were too small for the rivet. Is this normal? Is there more than one size tool for these things? I have attached a picture so you can see for yourself what I'm talking about. What am I doing wrong and how can I fix it? Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
dirtclod Posted February 14, 2010 Report Posted February 14, 2010 Ray your rivets maybe to long for thickness your going through. Quote I'm old enough to know that i don't know everything.
Members celticleather Posted February 14, 2010 Members Report Posted February 14, 2010 Ray I think you've reached the correct conclusion! I use rivet setters in three different sizes, according to the size of cap. Ideally, the diameter of the tool should be just a bee's knee larger than the rivet head. I also think it's important to use a bottom anvil of the same size (for double-capped rivets) or with the central projection for single-capped. Terry Quote When everyone is somebody, then no one's anybody
Contributing Member TwinOaks Posted February 14, 2010 Contributing Member Report Posted February 14, 2010 Cool effect with the rivets, Ray!!!! Wish I'd though of that. Also, I'd like to add the comment that proper rivet setting should sound like this: " Tap,tap,tap,tap,tap,tap,tap....", and not "....WHAM!.....Aw, dangit, bent another one...." --not that you would do so, Ray. There just always seems to be a new comer to the craft that doesn't understand it. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Contributing Member UKRay Posted February 14, 2010 Author Contributing Member Report Posted February 14, 2010 Cool effect with the rivets, Ray!!!! Wish I'd though of that. Also, I'd like to add the comment that proper rivet setting should sound like this: " Tap,tap,tap,tap,tap,tap,tap....", and not "....WHAM!.....Aw, dangit, bent another one...." --not that you would do so, Ray. There just always seems to be a new comer to the craft that doesn't understand it. Have you been hanging around outside my workroom again, Mike? To be honest, I was taught that a cap and stem rivet was a poor, cheap thing (the only good rivet was a properly set copper rivet) and they should only be used where nobody could see them, hence we didn't take a lot of time setting the things as they were just an ugly necessity. Having seen how good they can look (when set by the right hands!) I started to change my opinion, but I have only just got around to sorting out a suitable technique. Like most things to do with leatherwork it seems that there is a knack to cap and stem rivet setting and providing you have the right tools it isn't too difficult. Does anyone know where a well made set of rivet setters can be purchased as Tandy only seem to sell one size. Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Contributing Member TwinOaks Posted February 14, 2010 Contributing Member Report Posted February 14, 2010 Just experience with bent rivets, Ray. I STILL bend rivets on occasion, but I'll keep using them because they serve both aesthetic and functional roles. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Contributing Member UKRay Posted February 14, 2010 Author Contributing Member Report Posted February 14, 2010 Just experience with bent rivets, Ray. I STILL bend rivets on occasion, but I'll keep using them because they serve both aesthetic and functional roles. At this point in time, rivets are purely functional for me, LOL Thanks to Terry's mental database of where things might be found (thank you, sir!), I have now ordered a set of three different sized rivet setters from Le Prevo here in the UK. Hopefully my rivet setting will improve dramatically sometime soon. One last question though - how do you line up the anvil with the underside of the rivet when you can't see it? Is there a trick to this? Ray Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members oldtimer Posted February 14, 2010 Members Report Posted February 14, 2010 Ray. Are you using a copper rivet setter ? Do you have a pic of your rivet setter? I don´t think you have got the right setter! / Knut Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
Members celticleather Posted February 15, 2010 Members Report Posted February 15, 2010 One last question though - how do you line up the anvil with the underside of the rivet when you can't see it? Is there a trick to this? Ray If you're using open-ended (single-cap) tubular rivets, its helpful to use the rivet anvils that have an upstanding projection in the centre. It's easy to feel when the rivet bottom settles over the projecting nipple. Similarly, when using double-capped rivets, I find that using a bottom anvil with the same concavity as the top punch, helps to locate the bottom of the rivet accurately. It also prevents the rivets from skewing off sideways when pressure is applied. If you're using a mechanical rivet setter, it's obviously important to ensure that the top punch descends perfectly in line with the bottom anvil. The pic of my hand-setter shows the nipples on the interchangeable bottom anvils. Terry Quote When everyone is somebody, then no one's anybody
Members gary Posted February 15, 2010 Members Report Posted February 15, 2010 Cool effect with the rivets, Ray!!!! Wish I'd though of that. Also, I'd like to add the comment that proper rivet setting should sound like this: " Tap,tap,tap,tap,tap,tap,tap....", and not "....WHAM!.....Aw, dangit, bent another one...." --not that you would do so, Ray. There just always seems to be a new comer to the craft that doesn't understand it. So " Wham, wham, wham, wham, wham, wham, wham, wham....Oops...." is wrong? Quote
Contributing Member UKRay Posted February 15, 2010 Author Contributing Member Report Posted February 15, 2010 So " Wham, wham, wham, wham, wham, wham, wham, wham....Oops...." is wrong? Apparently so... It worked okay for me, but... Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members yan Posted February 25, 2010 Members Report Posted February 25, 2010 (edited) Until recently the only leather work I've done consisted of punching hole and riveting leather. I had modified a pair of vise-grips so they dont leave a mark on the head. I've been thinking about modifing on pair to get a distingtive mark on the rivet. It is a lot faster the hammering, and cheaper then the "official tool" It is useful since i do most of my work when kids are sleeping (bangning noise + sleeping kids= very bad evening) Edited February 25, 2010 by yan Quote
Contributing Member UKRay Posted February 25, 2010 Author Contributing Member Report Posted February 25, 2010 Like most of the leatherworking problems we face, it is so easy when someone tells you what you are doing wrong. I just received a package of three different sized rivet setters that have solved the problem completely... or have they? I'm now looking at ways to set the things silently and with more accuracy than was previously possible and have decided that a foot press is the only way to go. I also thought of using mole grips to take advantage of the extra leverage they offer but found it quite hard to be as precise as I wanted. Using a foot press means you have both hands to hold and position the rivet under the tool before depressing and squeezing the thing closed. Weaver do produce one and so do a number of other US based companies but over here in the UK we have to make do with the local engineering company or a friendly mate with a lathe. I'll let you know how I get on... Ray Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Ambassador Luke Hatley Posted February 25, 2010 Ambassador Report Posted February 25, 2010 (edited) Ray, there are some times that you have to use different tools for the job at hand. it took me two years of searching to find the right foot press to set tubular rivetts. Mainly the price was a factor in getting this one. it would have been a very hard task to set the rivets with a maul and setting tool on these tool pouches. Edited February 25, 2010 by Luke Hatley Quote Luke
