Members HarleyPete Posted March 5, 2010 Members Report Posted March 5, 2010 In the UK we can get a hard foam that is used for orthopaedic padding and seating. I think it is known as M60 foam and can be bought from good upholstering suppliers. it can be filed or shaped with a sureform.I use a 1/2 to 3/4 re constituted foam that is a bit firmer then a cover of M60 then shape to requirements. If you want more help send a PM and I will give you my number. Pete Smallwood, Irlam M44 Quote
Members bustedlifter Posted March 6, 2010 Members Report Posted March 6, 2010 Where can we get such an innertube as that. I'd like to give it a try. That's a 200-50 inner tube used in Razor scooter tires. You can get them from the Razor Scooter Store or Razorama. The smallest tube I can get locally is a 280/250-4 but it is quite a bit wider than the Razor tube. Quote
Members 8ball Posted March 29, 2010 Members Report Posted March 29, 2010 (edited) Hi there Im in the Uk and am too just starting on seats. I work with shoe repairs and will be using what they call in the trade 'micra' it comes in loads of thickness's and can be easly shaped using a sanding wheel attatched to a drill, or if you have a nice shoes repairer (like me ) they mit let you use there finishing machine you can get a super smooth finish and bonding the layers is real easy with neoprene glue, used for leather soles and rubber soles on shoes . hope this helps and hope to get into a Uk network of leather works great site cheers shaun Edited March 29, 2010 by 8ball Quote
