PapaWolf Report post Posted April 11, 2008 Before I go and leave this thing unfinished or screw it up, after you cut with your swivel knife you bevel the outer or inner edge? And you bevel to open the cut up a little and make it more defined right? Quote Share this post Link to post Share on other sites
Regis Report post Posted April 11, 2008 (edited) Well, Yes, yes, and maybe. There are a lot of reasons to bevel one side or the other but, I can tell you one where you bevel both sides of the cut. For example, you may want to show and animal's foot touching the ground and you would bevel both the foot (to begin rounding up the foot) and the ground (to begin showing it comming nearer to you). Same hols true for many things like rock on bare ground or squirrel sitting on a log. The best way for me to visuallize one side or the other is with an oak leaf carved standard then inverted. There are lots of folk here that can do better job of explaining. Regis Edited April 11, 2008 by Regis Quote Share this post Link to post Share on other sites
TwinOaks Report post Posted April 12, 2008 Yes, papawolf, that's the basic premise. For 'standard' carving: draw a circle (arbitrary object); beveling the outside of the line will have the effect of 'raising' the circle. Alternately, if you carve the inside of the line, it would 'sink'. In inverted carving, the entire circle would 'matted', or compressed. This makes what I can best describe as a negative image. I think you're talking about standard carving. Regis has it right regarding beveling both sides too. If you bevel properly, you won't actually open up the cut, but will lower one side of it. Quote Share this post Link to post Share on other sites
ferret Report post Posted April 12, 2008 Might be worthwhile getting Al Stohlmans "figure carving finesse", it explains about reverse bevelling and double bevvelling and lots of other useful technical stuff. Quote Share this post Link to post Share on other sites
Regis Report post Posted April 12, 2008 Ferret is right, that is a GREAT book. Quote Share this post Link to post Share on other sites
