Topcat
Superior Cutter For Leather Work....a Must Have!
Here is a tip that is one of the best tools I have ever used. Do you use a utility knife with break off blades? The wide ones are awkward and the thin ones don't seem to cut very well....until you buy the follows blades.....Tajima 30* snap off utility cutter blades.....they are so sharp they will cut you for touching them and go thru leather like butter. I think they work so well because of the 30* angle. Don't buy 60* blades as they are not near as effective. The blades will fit a standard knife but the break off front angle is incorrect and the vendor sell a slick knife that goes along with this blade. Remember 30*. YOU WILL FIND THEM ON EBAY.....try them.....you will never use anything else.....also give them a lot of respect....they are sharper than a razor blade....cheers.....Topcat
