Members Topcat Posted May 10, 2010 Members Report Posted May 10, 2010 from a previous post one contributor suggested coco bolo wood was the best? I had mentioned that nylon with moly was better than nylon(it is) I turn all my burnishing pieces to fit dremmel threaded studs with hand ground metal lathe bits. The coco bolo wood turns like bronze and threads equaly well. I made a couple of pieces and put them to work on current projects. WOW no comparison.....coco bolo is by far the best and the results are outstanding. I believe its the oil in the wood and the fact it runs much cooler. My foreman says all the brains can't be in one head and this proves it. A bigger disc on a drill press or whatever works equaly well.....but so much slower....cheers.....Topcat Quote Timothy "Topcat" Cantwell
