Members Drover Posted June 22, 2010 Members Report Posted June 22, 2010 I have just started to play around with a sewing machine (132K6) I have just bought, and was trying to sew two strips of leather together to make some reins the other day, I was rather close to the edge. The leather kept going out the left hand side and I am having trouble keeping the leather straight with just holding it. I was just wondering if it just requires more practice or is there something else I should be doing. Also is there some way I can slow the machine down, at least until I get better at controlling it, I was thinking about putting a smaller bit on the end of the motor, I think that would slow it down, but I don't know how small I can go, or where I would get one. Jason Quote
Cobra Steve Posted June 22, 2010 Report Posted June 22, 2010 I have just started to play around with a sewing machine (132K6) I have just bought, and was trying to sew two strips of leather together to make some reins the other day, I was rather close to the edge. The leather kept going out the left hand side and I am having trouble keeping the leather straight with just holding it. I was just wondering if it just requires more practice or is there something else I should be doing. Also is there some way I can slow the machine down, at least until I get better at controlling it, I was thinking about putting a smaller bit on the end of the motor, I think that would slow it down, but I don't know how small I can go, or where I would get one. Jason Hi Jason, there are many factors to consider regarding this issue. First of all the machine should be set up for leather. The correct presser feet, needle plate, and feed dog are a must. They must be smooth so they do not mark the leather, and depending on the application, a left, right or double toe foot will be needed. Using a leather point needle should also be used. There are guides that will help keep the leather straight that are also available. As for the speed, yes a smaller pulley on the motor will help slow the motor down, but the best way to slow it down is to use a speed reducer with a servo motor. If you choose to, you can call a number of sewing machine dealers that should be willing to help you, including myself. Thank you, Steve Quote
Members jimsaddler Posted June 22, 2010 Members Report Posted June 22, 2010 I have just started to play around with a sewing machine (132K6) I have just bought, and was trying to sew two strips of leather together to make some reins the other day, I was rather close to the edge. The leather kept going out the left hand side and I am having trouble keeping the leather straight with just holding it. I was just wondering if it just requires more practice or is there something else I should be doing. Also is there some way I can slow the machine down, at least until I get better at controlling it, I was thinking about putting a smaller bit on the end of the motor, I think that would slow it down, but I don't know how small I can go, or where I would get one. Jason Hi Drover You need an edge guide to sew up to. Are you an Aussie? If so give me a call and I'll walk you through whats needed. For the speed, put an 1 1/4" Pulley on the Motor and run the drive Belt a slightly loose so it doesn't jump away to start. or you can buy a Servo Vari Speed Motor that will run from 600 revs and upwards. Don't buy less than 500 watts / 3/4 HP though, as smaller will burn out. Make sure you have a LR point needle also for Leather work. Kindest Regards. Jim Saddler. Quote
Members Drover Posted June 23, 2010 Author Members Report Posted June 23, 2010 Thankyou for the reply's I will send you a Pm Jim, I am just outside Brisbane. Thanks again Jason Quote
