Contributing Member Clay Posted June 24, 2010 Contributing Member Report Posted June 24, 2010 I have started on my workshop and I can hardly wait till it is done so that I can start pounding leather. The first project I have done is a new tooling bench. There is a space in the garage in between the water heater closet and the heater/ac closet that was just the right size for a tooling bench. I think the space was ment for a freezer. I used a quality particle board with a laminated surface for the top of the work bench. The front edge of the bench is set back 10 inches so that I could have the bench under my elbows with out having to lean forward as much. I cut out the center so that I could drop the granite slab in and make it flush with the surface. When it is all done there will be shelves both under the bench in the space to the right and left of where I will sit and also on top of the bench. I have a tendancy to over build and this thing was a beast to get inplace by myself. but I think it will be sturdy and make a good work bench. I plan to build another 8ft x 4ft cutting table and a smaller 8ft x 2.5ft counter type space when this bench is done. Those along with more shelving and I will be up and running! Quote Clay Miller
dirtclod Posted June 24, 2010 Report Posted June 24, 2010 (edited) hi Clay, i really like the ideal of having the cut out in the front. I think if i was you i would bring the 2x4's that hold your slab out even with the front of the cut out. Particle board isn't the most stable thing to build out of. That way it would keep the front piece from cracking over time. It may not crack but why take a chance. Just my thoughts. Be sure and post pictures when you the rest built. It's always great to see some else's ideals and set up. John Edited June 24, 2010 by dirtclod Quote I'm old enough to know that i don't know everything.
Contributing Member Clay Posted June 24, 2010 Author Contributing Member Report Posted June 24, 2010 John, Thanks for the suggestion. I have 8- 2x3's supporting the weight of the rock. They run from left to right from the front of the bench and are attached to 2x4's that run from the back to the front. Then to go over kill, I have another 2- 2x4's that scab it all together. I will post a picture of it later this evening. I see your point of adding a little more support to the front edge. Will look at it some more..Thanks I just finished the shelves for the lower protion of the work bench. They came out ok but I had to re-cut one of the shelves to get it to fit. Here is a picture of the bench with shelves added. Quote Clay Miller
Contributing Member Clay Posted June 25, 2010 Author Contributing Member Report Posted June 25, 2010 I started on work bench number two this morning. I thought I was done with it, but after looking at the photo I think it needs some more legs in the middle and a shelf under the side across from the drawers. I spent half the morning trying to figure out the layout for the rest of my tables and assorted equipment. I am barely going to have enough room to walk around once I set it all up but it will fit. The space I am using is 18 ft by 16.5 ft and I am using it all up. ClayM. Quote Clay Miller
dirtclod Posted June 26, 2010 Report Posted June 26, 2010 A person can never how to much storage space, be it shelves or drawers. You could put cleats on side of the drawers and build a set of legs in the middle then your shelves are shorter and will hold more weight without bending out of shape. Plus you could get adjustable shelf tracks and clips then you can move the shelves where ever you want them. That's what i did on the wall cabinets i built in my shop. I would run a 2x4 across the front and back at the bottom to tie the legs togeather and it will make your whole bench more stable. Your going to have a fine set up in your shop. John Quote I'm old enough to know that i don't know everything.
Contributing Member Clay Posted June 27, 2010 Author Contributing Member Report Posted June 27, 2010 Finished bench #2 today. I added the legs and shelves. it is solid as a rock. I also hung some shelves on the wall above the bench. I found a cool thing for hanging tracing film and other paper rolls. It is a shoe rack but it works great for this too. I started on the new cutting table. It needs a piece of plywood for the storage area underneath. ClayM. Quote Clay Miller
dirtclod Posted June 27, 2010 Report Posted June 27, 2010 (edited) Hi Clay, your shop is looking great. I do have a question about the drill press lathe combo. What brand is it and does the drill press head swing out of the way so you can turn a bigger piece on the lathe ? I never seen one like that. Your tracing paper rack is neat to. Oh you have some real nice work on your site to. John Edited June 27, 2010 by dirtclod Quote I'm old enough to know that i don't know everything.
Contributing Member Clay Posted June 27, 2010 Author Contributing Member Report Posted June 27, 2010 John, the mill lathe is made by General Machinery. It is a Harbor Freight inport. The mill does swing out from the lathe. Quote Clay Miller
Members alb Posted June 27, 2010 Members Report Posted June 27, 2010 Your shop is shaping up! Looks like you're doing a great job. One note - I have a large cutting table that I also use for doing a lot of my work - riveting, punching holes, etc. It has a large shelf underneath that the previous owner used for leather storage. On the top, one side invariably gets filled up with "stuff" - knives, hole punches, some of the other stuff that I use all the time. If you will be using that table for things other than just cutting, you might want to consider adding a couple of drawers right underneath the cutting surface. It will help keep the cutting surface clear. Thanks for posting the pictures! Ann Quote
Contributing Member Clay Posted June 28, 2010 Author Contributing Member Report Posted June 28, 2010 Ann, Great idea on the drawers for the cutting table. I will def add some. Thanks. ClayM. Quote Clay Miller
