These are just a few stamps I have done for a recent client.
I'm making them from delrin and laser engraving them. These are 1 inch stamps and are made on flat plastic rather than the rod used by other engravers.
They are mostly for use with an arbor press, but I have fastened a stamp handle from a simple 6" pipe and two flat brass caps. A little double stick tape works well
for holding the stamps in place for use.
"Out of my mind.....back in 5 minutes"
Those little stamps are great!........ Jeff
Horsewreck, aka, Jeff M. Hairgrove
I'm curious what the cost is for an average stamp?
I need my logo stamp made and am looking for the right person to do it... Cost is a factor, but I'm more concerned with delrin rods bouncing around when struck. I like the idea of yours being more of a PRESS style application.
Troy
Hello. Delrin sheet is not too expensive so I'm doing it for $7-$8 (simple beer money) for a one inch stamp. Mostly because I get to keep one too.
However, I'm not doing any artwork design. It's one thing to trace a vector drawing in corel but it's another thing to do the artwork from
scratch. I don't have time for that. Cheers.
Edited by Studio-N
I've also been working on laser cutting Delrin stamps and am currently using a small hydraulic press to set them. What I would like to find is a way to set a delrin handle into a delrin stamp. I have found it difficult stuff to glue - but I'm probably using the wrong adhesive.
Has anyone had any success with joining delrin pieces. I wondered if welding them with a jeweller's gas torch might be a better bet?
Ray
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
Ray, I found this: http://www.reltekllc.com/primers-adhesion-promoters-for-Delrin-Acetal.htm in a quick search. Google "bonding Delrin" for more possibilities.
Mike DeLoach
Well they are not ALL successful. Here is a POW-MIA stamp I did for a friend.
The impression on the forground and background turned out good, but the lettering did not.
After it is shrunk down, it tends to blur together. It should still work out good on a large plate, but
I had to leave it off on the 1" stamps.
I don't know if it would work for "joining delrin pieces"
but I found a great new glue that has worked in many
circumstances for me... it is called Gorilla Glue.
You just have to use a tiny bit and it holds Like New.
Just watch out and don''t use too much, because it foams up a bit
Hope this helps
Edited by LNLeather
~Cheryl
There are many things in life that will catch your eye,
but only a few will catch your heart...
pursue those...
Hope this helps
Thanks, LNLeather, that Gorilla Glue is amazing stuff and really versatile too but sadly it won't work with Delrin which was designed not to be sticky... hence I have the problem! LOL
I had foam all over my bench the first time I tried it... we learn from experience I guess.
Ray
Ray Hatley
...I had foam all over my bench the first time I tried it...
It's deja vu all over again. I had the same experience. They should really put a warning label on the stuff - "A little goes a long way. A lot explodes into a really long way"
