Just wondering what you braiders think of brian neuberts string cutter/beveler. I use a similar type cutter/beveler that was locally made, the collar has a set screw on the bottom that never seems to hold that great and is very difficult to set accuarately when beveling strings, it just does not work well enough to get a consistent bevel on my strings. Neuberts looks like it should work very well when it comes to setting the collar for adjustment. He is coming out this way in a couple months, I might see if he could bring his cutter/beveler with him.
thanks in advance for you help
check out www.stevemasonsaddles.com
check out my saddle blog
Steve
I've got Mr. Neuberts string cutter/beveler and I think it works great. I can cut very fine strings with it. I don't bevel much because my strings are so small but what little beveling I do it works great. The cutter/beveler is pretty easy to adjust in small amounts due to the dail that you use to make adjustments. Mr. Neubert is good people and will take the time to answer any and all ?'s on all aspects of braiding. Just my .02cents worth
Mike
  • 4 weeks later...
