Members pearlygirl555 Posted August 19, 2010 Members Report Posted August 19, 2010 Hello I'm gathering supplies to begin making moccasins from 9-ounce buffalo. Bought a used but much-adored Consew 228 and have a question about bonded polyester thread vs nylon. It's been recommended that I use Coats Star Ultra Dee DB138 for the sole work and the same in DB92 for everything else. So far I've had an easier time finding the same weight in 100% nylon marine thread. Will the marine thread work just as well, or will the nylon be too hard on the holes as the moccasin wears, and I really should hold out for the cotton/poly blend? Thanks in advance for any responses. Quote "You're a guest of nature.....so behave!"
Members albane Posted August 19, 2010 Members Report Posted August 19, 2010 I would use the nylon it will hold up longer poly is only better if uv is a factor. Hello I'm gathering supplies to begin making moccasins from 9-ounce buffalo. Bought a used but much-adored Consew 228 and have a question about bonded polyester thread vs nylon. It's been recommended that I use Coats Star Ultra Dee DB138 for the sole work and the same in DB92 for everything else. So far I've had an easier time finding the same weight in 100% nylon marine thread. Will the marine thread work just as well, or will the nylon be too hard on the holes as the moccasin wears, and I really should hold out for the cotton/poly blend? Thanks in advance for any responses. Quote Al Bane<br />Al Bane For Leather<br />818 209 7945 <br />www.myspace.com/albaneforleather<br />www.facebook.com/albaneforleather<br />www.albaneforleather.etsy.com
Members pearlygirl555 Posted August 19, 2010 Author Members Report Posted August 19, 2010 Thanks much! Quote "You're a guest of nature.....so behave!"
Members alb Posted August 19, 2010 Members Report Posted August 19, 2010 SFS ASSOCIATES, INC. DAN BUSSE 5450 HIGHLAND PARK DR. ST. LOUIS, MO 63110 Phone: 314-531-1830 Fax: 314-531-1882 These guys know everything there is to know about thread (and most large scale leather equipment) and they are GREAT to deal with whether you are a hobbiest or a huge shop. Ann Quote
