hidepounder Posted August 31, 2010 Report Posted August 31, 2010 That's pretty interesting, Ben. As I said I use the 16 oz maul the most. But I prefer to use the 24 oz maul for most of my basket stamping which is right in line with what your study showed. My first maul was a 20 oz which I got along with just fine until I acquired the other sizes. So if circumstances dictate the purchase of only one maul, a 20 oz would be my choice. Quote
gtwister09 Posted August 31, 2010 Report Posted August 31, 2010 Bob makes an excellent point about the acquisition of tools and making do with your first purchase if you only can purchase one. Everyone is different in making a decision based on what type of tooling you do most or you can meet in the middle like Bob said. Regards, Ben Quote
Moderator bruce johnson Posted September 1, 2010 Moderator Report Posted September 1, 2010 To throw another iron in the fire here, total weight is not the only consideration in an maul. Balance is also a factor. For instance I have mauls from three makers. To compare between two 16 oz mauls, my Barry King is more neutrally weighted and my Wayne Jueshcke feels more heavy to the head. I use them both but prefer the BK on most tools and the WJ for small geometrics and baskets or larger surface area tools like thumbprints. I use some larger mauls too and match them to the size of the stamp. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Ambassador abn Posted September 1, 2010 Ambassador Report Posted September 1, 2010 Another vote for 16 oz. as a good all-around weight, but I've always preferred a mallet. Fascinating topic... It's interesting to learn what everyone else is using. Quote
gtwister09 Posted September 1, 2010 Report Posted September 1, 2010 Bruce, Balance is a HUGE deal for me as well. The handle design contributes to this as well as the head materials and head weights. Ed and I have had some long conversations about maul designs, balance and materials. How people use the maul as well impact this as well. Regards, Ben Quote
BearMan Posted September 1, 2010 Report Posted September 1, 2010 Hi Everybody, It looks like you are getting some very good advice here! Everybody is right, weight is a important factor, just as balance is,,, but another very important factor, is the head material. After making mauls for a few years using a type of white head material, I knew there had to be something that works, a bit better. With the much appreciated help from Ben & Bobby, "I've seen the light",,, that Bob Beard knew several years ago about the material I use now. The weights, I make most often fall pretty much right in line with the charts that Ben posted, with one exception, I make a lot of 18oz mauls. I don't get into the heavier weight above 24oz. A well balanced maul will make your tooling a lot less painful on your arm. From what I understand, my mauls, as far as balance, fall right in between Wayne's & Barry's. I haven't used any of Wayne's mauls, so I'm just going from what I've heard. Personally, I use a 17oz, for most everything, a 20oz, for the "heavy" stuff, a 14oz, for bargrounders & backgrounds, a 10oz for very delicate things, & a special very soft 26oz that doesn't bounce, for makers mark. When asked what size to start with, I usually suggest a 16oz, if you mostly do "Sheridan" or intricate types of tooling,,, or if you do heavier stuff, that uses larger stamps,,, possably like the "Porter" saddle designs,,, I'd suggest a 20oz. I hope this helps some,,, there are some very good mauls makers out there. Who ever you go with, I'm sure you'll see things getting a lot easier on your arm. Ed the"BearMan" Quote Ed the"BearMan" polarb1717@aol.com Beary: BearMauls@yahoo.com http://tinyurl.com/BearMauls "The Best tooling mauls available today!"
hidepounder Posted September 1, 2010 Report Posted September 1, 2010 Bruce & Ben you're both so right. Balance is everything. The tough part is trying them out to determine which maker's style you prefer. Going to a show is about the only way I know to compare them. As Ben mentioned there ae a variety of different style heads and handles and they both impact the feel of a maul. I use Beard mauls almost exclusively because I like them. However I have a 16 oz BK maul with a tapered head that I am crazy about also. I'm on my second head on that maul. I really like the taper on the maul, but I have a tendency to be lazy with my elbow because the taper allows me to lower my arm so much. I see a lot of WJ mauls out there with tapered heads also. I have never used a maul with the head turned like a mallet. I guess maybe they are mallets at that point. Anyway maybe someone can comment about those styles. They don't appeal to me because I don't care for the feel of a mallet but I think WJ and BK sell quite a few of them. The type of handle certainly impacts the feel of a maul. The traditional leather handles like BK and WJ make are hard to beat. I like the handle shape on my Beard mauls alot but some people don't care for them. It is easier to choke up on a handle shaped liked BK makes than it is on a Beard. I love the look of the hardwood handles that Ed is making. They almost look like trophies. And Ed is offering different head materials and handle shapes which is something new. We haven't had a lot of those choices in the past. I might also mention that Casey Jordon is now engraving the hardware on BK mauls for the tooler who has everything! I suppose no discussion about tooling mauls would be complete without mentioning stamping sticks. I don't use them anymore, but sure prefer them over mallets. There is probably an opportunity for someone to make a buck by re-introducing them. They have kind of been forgotten over the years. They were mostly home made and were commonly seen with single and double heads. The double headed sticks were pretty fast to tool with. I just always thought they were a nusance to recover, but with some of the new materials available now, stamping sticks could make a comeback. Quote
Members TroyWest Posted September 1, 2010 Members Report Posted September 1, 2010 (edited) This is an interesting topic. I'm another fan of 16oz. BK maul. That is what I use the most for general tooling.It has a straight head on it. I have a heavier Gore maul I use for Basket stamping. I have a Beard 32oz.. I love the material but its much too head heavy for me. I only use it for drive punches. When I used to use the big poly maul for tooling I would occasionally shoot a tool off to one side. Using the little BK I never do. It is also very well balanced. I bought a tapered head BK maul last year but when I got home the handle on it was turned down a little thinner than the others and I found I actually had to squeeze a little to hold it and it was a little more tiring to tool with it. It still looks brand new. I think I'm going to trade it back in for one with a little fatter handle. At our other shop we had a 56 oz. Beard maul that was great for large drive punches and firm stamps. Bob, I think your double headed stick idea sounds good. Edited September 1, 2010 by TroyWest Quote
Members David Genadek Posted September 1, 2010 Members Report Posted September 1, 2010 I have a lot of trouble with the bolts breaking on all of them. One of my John Bianchi just had all the threads strip out while stamping. I had similer issue with my Barry King maul. This seems to happen with all wieghts and I have had big issue with heads working loose. David Genadek Quote
