pistol packin mama
Singer 34K11 Post Sewing Machine
Hi all out there! I have recently acquired a Singer 34K11 machine. What a beauty! I am in need of an instruction and service manual. Singer can't help! Anyone out there have one?
It's likely that Singer never produced the manuel you seek .
I may have a manual i'm not but i will look tomorrow. If i have one it's not for the same machine but it is a post Singer post machine.
If it is close, it may work. Having trouble theading the bobbin. It is also equipped with a 2 speed pulley but the motor only supports one at a time. I want to make sure that I get to all the grease fiitings and oil spots.
I just looked and i don't have a manual. My machine is a 51 w 56 and i did find a place to get a manual for it http://www.proleptic...show=100&page=3 . On mine i just put some oil in all of the holes. The bobbin should have a slit and a little clip on it that the thread goes behind if that makes any sense. You may be able to run it with either pulley. But i think you will need a different length belt longer or shorter depending on which one it's on now. Maybe somebody that knows alot more than me will stop by and help.
Edited by dirtclod
Thanks for the info and I will try the site.
