electrathon Posted October 27, 2010 Report Posted October 27, 2010 I would recomend using an antenna off a car. They are plentifull and are very hard. Stainless too so they will not discolor your leather like a will. Aaron Quote
Members ToddB 68 Posted November 2, 2010 Author Members Report Posted November 2, 2010 (edited) Howdy ! Trying to make my own diamond-shaped awl. ( have a haft with adjustable chuck.) I started with a "square-cut" concrete nail, because it's hard and already tapered lengthwise. Using my bench grinder, a flat file and a bucket of cool water, I worked the nail down to a more slender size while maintaining a lengthwise taper and cross sectional rectangular shape. Now I need to add the diamond shape. Does anyone have a design for a fixture to make an awl cross sectionally diamond shaped ? I am looking for something that could be made from hardwood and/or metal in my workshop. The fixture does not need to hold tight tolerances on the finished product (the awl). I would be satisfied with a close approximation of a diamond shape. In fact, what I mostly need is a design concept and then I can work out the construction details and fine-tune the fixture to hold my personal accuracy requirements. Thanks for whatever help you can offer. ToddB68 Hi All ! Attached are photo's of my completed Awl Blade, i.e. a full view of the awl mounted in an old haft I got from my Dad years ago, along with a side-by-side sample of the concrete nail used. Also, three sectional photo's of the completed awl blade, for close-up views. This, my first attempt at making an awl blade, turned out a little too thin in the forward section, but will still work for the leather tool sheath I'm in the process of making. I tested it and by using Bees wax on the blade, was able to push through two dry layers of 12oz. veg-tanned leather without the blade flexing. Of course, I had to take it easy and push slowly. In the future, I plan to make another blade, but it will be somewhat thicker cross-sectionally throughout the entire length. ToddB68 Edited November 2, 2010 by ToddB68 Quote
Members ToddB 68 Posted November 2, 2010 Author Members Report Posted November 2, 2010 (edited) Hi All ! Attached are photo's of my completed Awl Blade, i.e. a full view of the awl mounted in an old haft I got from my Dad years ago, along with a side-by-side sample of the concrete nail used. Also, three sectional photo's of the completed awl blade, for close-up views. This, my first attempt at making an awl blade, turned out a little too thin in the forward section, but will still work for the leather tool sheath I'm in the process of making. I tested it and by using Bees wax on the blade, was able to push through two dry layers of 12oz. veg-tanned leather without the blade flexing. Of course, I had to take it easy and push slowly. In the future, I plan to make another blade, but it will be somewhat thicker cross-sectionally throughout the entire length. ToddB68 Whoops ! Forgot to attach the photo's........see below. Edited November 2, 2010 by ToddB68 Quote
Members Albe Posted April 7, 2015 Members Report Posted April 7, 2015 Thanks Guys. Just made me one after my shop bought awl snapped last night close to the end of my first project. Quote
