I just checked out the Gatco video. Couple questions for you.
1. Do you put the angel jig to the left or right of the handle or does it not matter?
2. Do you go back and forth with the stornes or in a circle?
Well it doesnt matter what side you put the handle on. on one of my knives I have to do half of the blade and then put the handle on the other side, but as long as you stay with the same angle it works out . I was trying to go back and forth but had way better results using small circles
Tim Worley
TK-Leather
If you don't ask and dont try how are you gonna learn anything?
Hi Guys,
I've used the Lansky system for years, which lokos very similar to the Gatco one. I hadn't seen the Gatco one until I saw it in this thread - it actually looks more comprehensive than the Lansky one (Thanks for pointing it out, Tim).
Just to add my tuppence here to Tim's notes above........
Do eveything Tim says, but remember to overlap your strokes when you move the jig to the other side of the handle, so that you get the same angle all the way across the blade.
One problem I have with the Lansky system which I think the Gatco system seems to solve is that my guide rods for the hones work loose, causing the the hones to swivel and become unlevel. I always put my hone and guide rod assembly on my skiving slab to make sure the face of the hone and guide rod are properly level before I tighten the screw to secure the rod to the hone. This ensures that the angle I'm using is accurate and consistent (Gatco seems to have fixed the hone guides in place so that you won't have that issue) and its a real pain to have to stop making small circles to have to re-level the whole thing every few minutes when they work loose....
Think I'll have a look at the Gatco system properly!
All the best,
Jerry
All the best,
Jerry
"There is nothing better for the inside of a man than the outside of a horse" Will Rogers 1879-1935 quoting Sir Winston Churchill 1874-1965
I just bought one of the new Damascus Round Knives from Tandy. I figured for the price on sale, I couldn't beat it for a starter knife. It was pretty sharp when I got it, but it wouldn't shave.
I've had a Lansky system for probably 25 years or more. I have never had a problem with it getting lose while I was using it. I did have one of the little brass inserts pull/break out of a stone. Luckily, I had received a second system as a gift, so I had an extra stone to replace it.
I also reposition the jig to both sides of the handle in order to sharpen both sides of the blade. I have never used circles, but just use long even strokes going from the edge back towards the handle while moving it across the blade. I also count the number of strokes that I use, usually starting at 20 on each side and working my way back to only 1 stroke per side. If it is the first time I've sharpened a blade, I start with the coarse stone, then the medium, and lastly the fine. I don't have the ultra fine or diamond hone. As I sharpen I flip the blade each time I count down in order to sharpen BOTH sides equally.
After using the stone, I used jewelers rouge on leather to strop it. It was shaving even before stropping, but that really polished the blade!
I have not seen the video of the Gatco yet, but will watch it. Thanks for sharing.
Jerry, why don't you use some Locktite on the threads when you put the rod in? Then just leave them together instead of taking them apart for storage. I also put mine on top of a flat surface when I put on the rod in order to get them all at the same level with the stone.
Bobby Riddle
Sanford, NC
www.riddlescustomupholstery.com
www.sunstopper.biz
Bobby,
Thanks for the Loktite tip. Unfortuately that would mean I would have to leave them out of the box, which would, invenitably, lead to them becoming misplaced. I'll give it a go for my next dedicated session, though, because i've also got some superglue remover....! I also like the discipline of counting your strokes.
Thanks again.
Jerry
All the best,
Jerry
