Just came to my mind ...
Which way you'd go in making a ccw belt when using exotic skins as a part of it :
1 ) 9-10 oz for belt , 4-5 oz for lining PLUS a decorative panel (stingray , shark ...) on top
OR
1) 9-10 for a lining AND a heavy panel on that ( again shark / stingray ...) ?
And yes , I'd like to use a decor like that , kinda hits my eye.
Suggestions for thicknesses will be appreciated .
My old belt has given me much more than suggested 5 or so years , but seems that I'll need a new one later.
Edited by JackRabbit
Fast is fine but accuracy is final .
Does anyone cut thier belts on a curve?
I haven't but I've wetted down a strap and shaped a curve into it, let it dry and turned out pretty good. (I never made a belt out of it however, I ended up using the piece on another project.)
I'm also of the opinion that a straight strap will take on the contour of the new body soon enough.
Rayban
www.rgleather.net
Which is a fact , it will shape to fit to YOUR waist.
Just wear the belt , that's all it takes.
JR
I need to make another belt for myself. I made my first one, good for daily use and for concealed carry and it's finally time to get started on another one after 16 years of almost daily wear, 7 days a week. It was veg tanned water buffalo, from Tandy. I did cut it on the curve, and sized it to 1 3/8" width. It's just a plain black belt and all saddle stitched by hand. The stitching got worn in a few places but with the saddle stitching, it never did un-ravel, just had a few bad spots so I would go back and re-stitch as needed.
Man...hand stitching these long belts is a chore but a fun one. I don't do it very often so I'm not fast at it, and I'm sure my diamond awl wasn't sharp enough but I learned a lot from the first one and expect this next one to turn out even better.
Does anyone use any other material as a stiffner? The best belts (utility wise) I have found are from CompTac. Here The are double thickness with a Kydex liner. I would love to make something similar but have yet to find a supplier of a kydex or similar stiffener.
A fella was over just yesterday to show me his Kydex reinforced belt. He somehow folded it and now has an ever-lasting fold crease in the Kydex and can't get it out...he's got a nice fold line in his belt.
Rayban
www.rgleather.net
My experience is that a proper made belt, double thick leather of veg tan, will not need any further stiffener to support a properly sized holster where the loops match the belt width. A well made belt of such construction as what I used is very stiff indeed.
Let's say you wish to make a belt, double thick which is two thicknesses of leather, say two 8 oz layers. Now think about the added thickness of the Kydex. It will add a lot of thickness if it's stiff enough kydex to add stiffness to your belt. I've made Kydex holsters and used a .08 Kydex. I've seen thinner used but I liked the stronger stuff. My hand sewn belt measures .275 thick, so add another .08, and it's gonna be one thick belt.
I just made a belt for my wife. Probably overdid it.
8/9oz cowhide backed with about 7 oz horsehide.
Might just be the last belt I ever make unless I get a sewing machine. That's a LOT of stitching!!!!!
You hand-stitched your wife a belt!!?? now THAT'S true love!!
Rayban
www.rgleather.net
