As far as what you have so far, I can only say that if you intend to use that holster with the pliers pointing down, they will probably wear a hole in the bottom of the holster quite quickly.
I did a holster for my gerber tool about a month ago. It was just a quick & dirty one I threw together because my nylon sheath was in tatters. I wet formed the leather around the pliers, then let it dry, put a snap on the outside of the holster, sewed a loop on the back, laced the back to the back, put a snap on the flap, threw some neatsfoot on it, and wore it. The wet forming was the hardest part because I was in a hurry.
One tip on the belt loop: make it a true loop, not a slit. By that I mean when you sew the loop on, start at the end that will be at the top of the belt, with the loop pointing even further up. Once the top is sewn on, fold the loop down and sew the bottom end. This makes it a little more flexible and forgiving when you snag it on something. I made cellphone holster that had a piece of leather on the back to form a belt slit, and almost gave myself a wedgie when the phone got caught on a grab bar as I was jumping off some machinery. I ended up hanging by the holster at some really crazy angle until I could stop swinging and get ahold of something to right myself. I've snagged my gerber holster several times already, and this loop has enough give to it that I don't get hung up.
Heheh - I did this once too....
check the date - ooooold post
:cheers:
~Cheryl
There are many things in life that will catch your eye,
but only a few will catch your heart...
pursue those...
