This board saved me from another potential pile of junked leather.
I have ordered some geometric stamps and would have gone ahead without thinking about leather stretch till i read about it here. I knew about stretch,but just that without this board, it wouldn't have occurred to me in my eagerness to start.
Anyway, seems the most popular method would be to glue the leather piece to cardboard. My question is,, if the flesh side would be exposed in the final product, won't the customer see bits of glue and card board all over the flesh side?
I used to glue posterboard to all of the stuff that I tooled and I was always getting the rubber cement all over, and I just think its messy but after reading on here about people using shipping tape on the back i tried that and it works great, so far all of the pieces that i have used it on have not stretched at all and i've tied it on everything from basket weaves to those huge tripoints and no stretch, i found that if you put it on one direction and then put another layer on the other direction then it works pretty good, the only problem I had was it was slippery on my board so I just put some masking tape on it and it quit sliding around. Of course the one drawback was it fuzzes up the back a little bit but not so bad that it looks bad on the stuff I do. Good luck hope this helps.
Bryan
Don't like sugar in my coffee But love coffee with my sugar!!!!!
bkingery, when you say "shipping tape", what exactly to you mean, please? The brown cellophane tape? The fiber-inserted "strapping tape"?
I guess I'm asking, "what's the name on the label"?
SHipping tape, the only kind I have used is the clear, seems to work best. Now I have seen one of the teachers at the local Tandy use self sticking shelf liner that seemed to work even better. It also releases a lot easier when done. I'm going to try that next.
I use the clear packing tape, no fibers. I have used the dollar store stuff with no issues, although a wallet has been my largest project.
I have not tried shipping tape but I do use painter's tape or masking tape in two layers, one going the length and the other the width. May be overkill, but it works for me and controls the stretch effectively. Don't be afraid to experiment, it's how most of us have settled on our process along with using what is readily available and affordable. Best of luck.
Jose Rodriguez
SoCal Leather Co.
Blue painters tape would be my choice then. It doesn't leave residue behind. Thanks kindly!
  • 4 weeks later...
I found contact paper, (shelf liner) to be excellent. A roll can cover large projects and it goes on in one piece and comes off the same way. Same price for painters tape but more product. Doesn't leave any residue either.
Chris
Hiya, i thought i would add my method, i use 2" plastick box tape clear or brown, then i put 2" double sided tape onto that (just the cheap stuff) and then stick the hole lot onto some card, overkill you may think.. but the card gives you something to hold you design onto pattern onto, when you have done and its totaly dry, peel the card/tape off the leather, not the leatherfrom the card, this as most will know will cause the leather to stretch, when you have done there is no glue on the leather, and no stretch, works for me,
Regards, Steve..
Life is not measured by the number of breaths we take , but buy the number of moment that take our breath away..
Steve.
www.bigsteves.co.uk
