grammyd Report post Posted January 26, 2011 I was wondering if anyone had any ideas on what to use inside a pool case to divide, and hold two section pool stick? Doris Quote Share this post Link to post Share on other sites
dirtclod Report post Posted January 26, 2011 Plastic pipe, cut to the length you need. Quote Share this post Link to post Share on other sites
RustyMelton Report post Posted January 26, 2011 (edited) Plastic pipe, cut to the length you need. Doris, Go to Lowes and get a piece of 1 1/4 inch pvc pipe and a piece of 3/4 pvc. Be sure and get the thinner variety, at the one here they have two types and cut it into the length that you need. Buy some good quality material and sew some socks that you'll slide down through the inside of the pieces of pipe, pull them over each end and tape them off. You'll need some padding in the top of your case and some in the bottom to protect the pieces of your cue. Edited January 26, 2011 by RustyMelton Quote Share this post Link to post Share on other sites
