Melanie Wilfong Report post Posted February 21, 2011 (edited) Would someone please let me know where I start to add an extension to the heel knot? I tied it using Grant's instructions. The last sequence on the heel knot was O3 U3 O3 U5. Grant's book says with this key the knot may be inreased. I've got a picture which shows a piece of lace poking straight up. Is this where I begin? How many O/U? I think I can figure out the sequence if someone can help me get started. Thanks. Do I just continue on with O4/U4? Edited February 21, 2011 by Melanie Wilfong Quote Share this post Link to post Share on other sites
Aggiebraider Report post Posted February 21, 2011 Yes you basically just keep going with O4 U4 but at the top and bottom you will go under more parts than you did the last time. Without getting a book out, I think you will go U5 at the top and U3 at the bottom. If you are using multiple colors (which I recommend), this will be easier and the pattern will start to show itself once you go around a couple times and start splitting pairs.' CW Quote Share this post Link to post Share on other sites
roo4u Report post Posted February 21, 2011 yup...just build and split more pairs going o4u4... Quote Share this post Link to post Share on other sites
Aggiebraider Report post Posted February 21, 2011 Youre also not technically "extending" the knot if by extending you mean make it longer. You are really just filling the middle in more to cover a larger object. The same principle can be applied when a smaller knot wont completely cover the foundation you are using. CW Quote Share this post Link to post Share on other sites
Melanie Wilfong Report post Posted February 21, 2011 Thank you. The last 3 rounds of the heel knot were identical; O3U3 until I got I got to the starting point. If I go up to o4/u4, do undo the last two o3/u3 rounds? Hope this makes sense. Quote Share this post Link to post Share on other sites
