You can buy the chuck if you don't have a spare one kicking around, they have a threaded hole in the back and this one happens to be a Jacobs 3/8 chuck with a 3/8-24 right hand threaded hole.
A 3/8-24 bolt with the head cut off or 3/8-24 threaded rod is cut to length and then turned into the 3/8-24 hole in the ram, add a flat washer and screw the chuck onto the threaded portion of the rod protruding from the bottom of the ram.
I also have the short adapters for the stamps where I can take the chuck out and screw in the adapter that I had threaded to 3/8-24.
post-19342-0-01036900-1428162514_thumb.j
  • Replies 35
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Thanks that's really helpful! I'll be buying an arbor press soon and this is a must-do for me
Half-Goat Leatherwork - Handmade in Scotland.
http://www.half-goat-leatherwork.co.uk/
You will lose some height with a smaller press when using a chuck so keep that in mind when choosing a press.It's also worthwhile having the adapter for the stamps if you still find one.
Pawn shops usually have lots of drills to choose from. You are looking for big as possible, as beat up as possible but with the nicest chuck, preferably jacobs. I once got a 1/2 inch milwaulkee drill for 30 bux with concrete splatters all over it but with perfect chuck. I bought it to replace the chuck on my own drill which had chowdered its guts. A new jacobs chuck was probably 10 times that.
"If nobody shares what they know, we will eventually all know nothing."
"There is no adventure in letting fear and common sense be your guide"
  • 2 months later...
Do you think you could use an Arbor press with cutting dies? Almost like a manual clicker press? Is there such a thing?
Yes, but it has to be in the 6-12 ton range....depending on the size of the die. There's an old thread on here somewhere showing some.
Rayban
www.rgleather.net
