Members LilRay Posted March 24, 2011 Members Report Posted March 24, 2011 Ray, I use the chisel on thinner leather, say sewing 2 3oz. pieces together. On thicker leather it makes the holes too big, although I sometimes will use it to lay out my stitch line on the thick stuff. I use the 1/8" chisel. I'm gonna be making a few wallets for friends. I don't guess the leather is over 4-5 oz For belts and holsters, using 8/9oz leather, FORGET about diamond chisels. I tried that. Broke two of the Tandy 4-prong diamond chisels (made of pot metal, apparently) before I gave up and started drilling holes. Then katsass schooled me in the merits of diamond-shaped stitching awls, and I got one, and once I got comfortable with its use, I'd never go back. As for belts, I've made ONE. I'll probably make one or two more, for myself. I wouldn't want to try it as a commercial venture, though, because it takes HOURS and HOURS to HAND-stitch a belt. Think about it. 40-60 inches of belt, stitching on both sides, 5-6 stitches per inch. That's at least 400 stitches. And you need about 4 times the length of thread as the length of the work. You spend most of your time pulling the thread through...... Gotta find a diamond awl then. How does one mark spacing then? God Bless, Ray Quote Ray
Members Big O Posted March 24, 2011 Members Report Posted March 24, 2011 You might check out "overstitch wheels". They're basically spiked wheels attached to a handle. You just roll the wheel along your stitch lines, and it dimples the leather in regular increments. They make different sizes. 5 or 6 holes per inch is pretty standard. I have one, and tried it, but couldn't see the marks consistently, so I usually just wing it. The bad news is that it's sometimes pretty OBVIOUS that I'm winging it. Quote https://www.facebook.com/BigOGunleather
Members azrider Posted March 24, 2011 Members Report Posted March 24, 2011 When you use an overstitch wheel, dampen the leather first. It makes it a lot easier to see the marks. I do all my stitching in a channel I gouge first, and just run my sponge along the channel before the overstitch wheel. If I dampen it right, I can actually feel the marks with the end of the awl, and don't have to look quite as closely. Quote Drygulch Leatherworks- Baldwin City, Kansas www.drygulchleather.com
Members lazybum Posted March 24, 2011 Members Report Posted March 24, 2011 Alternatively, get the diamond chisel and use it to mark the stitch holes by tapping it with a mallet. This makes it easier to angle your awl, though it takes a bit more time. Japan and the UK sells better quality diamond chisel. They're usually referred to as pricking irons. Quote
