Will Loctite keep the button stud screw-in base from coming loose?
I thought that I might notice if the base loosened, but no.
The stud only lasted three days, then it went missing.
Is there any special trick other than Loctite?
I could add a metal washer and a lock washer, but that seems a bit extreme.
Plus, it may not work at all if I do that (might be too thick).
Relly
Button stud
http://www.tandyleat...s/11310-02.aspx
Relly
Button stud
Try Nailpolish! Easier to loosen than Loctite if you should need to.
Tony.
I've used the blue loctite to keep screw conchos in place on motorcycle saddle bags. they held up fine over a lot of miles, but I was still able to remove them when I sold the bike.
Drygulch Leatherworks- Baldwin City, Kansas
www.drygulchleather.com
Thank you ... that gives me a lot of confidence on using the blue loctite. A bike vibrates plenty - if that didn't shake off the conchos, then I should be fine.
Relly
Button stud
I use the Sam Browne type that is tapped in and have been very happy with them. http://www.tandyleatherfactory.com/search/searchresults/1309-02.aspx and anvil http://www.tandyleatherfactory.com/search/searchresults/8112-00.aspx . I tried the screw in type and I guess they would have their application but wasn't happy them.
Thank you,
Rob Bennett
Email: rob@rmbcl.com
Authorized Distributor
BLUEGUNS
Multi Molds
Maker Supplies
Home of the "Taco Press" kydex/Leather former
FREE SHIPPING!
FACEBOOK
  • 2 months later...
Use Red locktite if you wanna keep stuff on permanently.
I mean Permanently, dont ever expect to get them off.
That stuff holds my Harley together, as well as the stud on my bags :)
Red Leather, Yellow Leather, Led Reather, Lellow lever, Yed Lede... aww crap....
