Members 1894leverguy Posted April 3, 2011 Members Report Posted April 3, 2011 The machine is a Cowboy 3500. When sewing two 1/8 in pieces of leather, should the top and bottom stitches look the same? On my machine, the top stitch looks good but the bottom isn’t near as tight The top stitch has a distinctive gap between each stitch but the bottom isn’t tight enough to have a distinctive stitch. While the bottom isn’t a bad stitch, it seems as though it could be improved a bit Thread tension appears good to me Are there any other adjustments? Quote
Trox Posted April 3, 2011 Report Posted April 3, 2011 Hi! That is because the needle is punching down true the leather and makes a exit wound. The bottom stitches will never look as good as the top ones on firm leather, this is normal. Hammering the seam flat will make it look better. You can use a sponge with some water before you hammer it; if needed. But this you know already. The bottom stitch looks better with one size thinner thread than the top one. Adjustment are the tension and foot pressure. The right size of needle will also matter. A shorter stitch might also improve. But post a picture of it, that is the only way to determine if it looks normal. Trox The machine is a Cowboy 3500. When sewing two 1/8 in pieces of leather, should the top and bottom stitches look the same? On my machine, the top stitch looks good but the bottom isn't near as tight The top stitch has a distinctive gap between each stitch but the bottom isn't tight enough to have a distinctive stitch. While the bottom isn't a bad stitch, it seems as though it could be improved a bit Thread tension appears good to me Are there any other adjustments? Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Contributing Member TwinOaks Posted April 3, 2011 Contributing Member Report Posted April 3, 2011 It depends on why the bottom doesn't have any gaps- If it's leather filling up the space between stitches, then you could try something like an overstitch wheel. If you see the top thread between the bottom stitches, you need to increase your top thread tension just a little so the lockstitch is pulled inside the leather. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
