Members shaggs Posted April 6, 2011 Author Members Report Posted April 6, 2011 Yes, it will work on that machine just fine. The 500GR has built-in 3:1 gear reduction. This makes it more powerful than it looks. It also limits the top speed of the motor to 1500 RPM. The SewPro 500GR mounts a little closer to the table than a clutch motor. You will lose one inch of belt length, if the motor feeds the machine directly, without a speed reducer. If there is a reducer in the system the belt change may be negligible and easily compensated for via the motor adjuster bolt. If it is feeding all the way up to the flywheel on the machine, buy a 1" shorter belt. If the pulley on the original motor is larger than 2 inches, subtract another inch for each inch that the SewPro is smaller. In my case, I replaced a clutch motor that had a 2.5" pulley with the SewPro motor and a 2" shorter belt. This positioned the motor a a favorable angle for the pedal rods to pull smoothly. Doh! I almost forgot the last question you asked! The existing belt will have a number after a letter. The letter probably is M. The number indicates the length of the belt, at the inside of the tapered belt's circumference. For instance, if the original says it is an M44, and the original motor has a 2" pulley, you would then order an M43 belt with the motor. If the original pulley is 2.5 or 3 inches, you would order an M42 belt (assuming a 44" to start with). The threaded adjuster allows for about 1.5 inches adjustment, up or down from the center point. But, the good operating angle occupies a range of about one inch, from the center down. Each pedal setup may differ from others and your floor pedal may allow a full range of adjustment, up or down, without binding. Mine didn't. Quote
Members shaggs Posted April 6, 2011 Author Members Report Posted April 6, 2011 Wow! You have been a great help and have answered so many questions for me,again I thank you for your knowledge and time. Time to go place my order...I feel much better about my machine now. Quote
Moderator Wizcrafts Posted April 6, 2011 Moderator Report Posted April 6, 2011 Wow! You have been a great help and have answered so many questions for me,again I thank you for your knowledge and time. Time to go place my order...I feel much better about my machine now. I re-read the entire thread and see that a couple of us mentioned where to get the SewPro 500GR motor, but nobody gave you the phone number. Toledo Industrial Sewing Machines: 866-362-7397. Tell them you heard about the motor here. Be sure you ask for the 2" pulley and remember what I said about getting a shorter v-belt. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members shaggs Posted April 6, 2011 Author Members Report Posted April 6, 2011 Will Do!! Thanks! I will let you know how it all goes. I re-read the entire thread and see that a couple of us mentioned where to get the SewPro 500GR motor, but nobody gave you the phone number. Toledo Industrial Sewing Machines: 866-362-7397. Tell them you heard about the motor here. Be sure you ask for the 2" pulley and remember what I said about getting a shorter v-belt. Quote
Members shaggs Posted April 13, 2011 Author Members Report Posted April 13, 2011 Just received my Sewpro motor and what a difference! Just the perfect speed and quiet...I love it! Thanks to all for your help! Will Do!! Thanks! I will let you know how it all goes. Quote
Moderator Wizcrafts Posted April 13, 2011 Moderator Report Posted April 13, 2011 Just received my Sewpro motor and what a difference! Just the perfect speed and quiet...I love it! Thanks to all for your help! The SewPro 500GR only draws a single watt when not engaged. It draws 300 watts at full load. Mine has never even gotten hot to the touch. By contrast, the 1/2 horsepower motor it replaced drew about 550 watts and could warm my expando in idle. The motor makes no sound in idle and it's easy to forget it is switched on. Remember to switch it off when it's not in use. You wouldn't want your kid or pet to accidentally push on the floor pedal and start the machine running. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
