I have a belt order I'm working on, it's my first one. The belt will have a tooled railroad track that goes around it, in the back the track will open to an elipse where the name will be tooled in the center. I did some practicing on the railroad tooling and I'm afraid if I dye the belt all mahogany (the color the customer wants), the tooling will be lost in the darkness of the dye.
So here's an idea that I'm thinking about doing.
After tooling, I'd like to take the mahogany dye and color everything but the tooled areas (both sides of the track to the edge of the belt and possibly the gravel areas between railroad ties). I'd like to leave the tooling natural and let it darken a bit when I oil and finish the belt.
What would be the best way to go about this? Should I paint the dye in with a fine edge artist brush near the tooling and finish it with a dauber/foam brush? Or, should I paint some type of resist on the entire tooled area then dye the belt allowing the resist to block the dye?
Other options to consider?
Thanks in advance!!
Craig Collier
~Grizzly Custom Knives~
I'd like to know this too.
God Bless, Ray
Ray
Perhaps between the 2 of us we can get an answer today :)
Craig Collier
Take one of the pieces that you have been practicing with and dye it with brush and see how you like it and how it works out.
I'm old enough to know that i don't know everything.
:) Sure, trial and error is the easy part! I was hoping that some of the more experienced craftsman could throw out a few pointers and 'keep in minds' to make it a bit simpler.
Craig Collier
Something like this?
I used a fine tipped brush for the background and edges around the tooled pattern, and wide brush for the open areas of the edges. A couple of coats of die till I got the effect I wanted, followed by buffing after the die dried. A light coat of neatsfoot oil that I allowed to dry overnight, followed by a coat of Neat Lac as a resist before applying the antique and final coats of Neat Lac.
  • Ambassador
I would use a brush as well. A word of caution ....dont try to do this with a cheapo brush. If you own a set of good brushes the job will be easy. I dont mean 'better' quality brushes...i mean 'good'!!! Good quality sable brushes are the only way to go, but be prepared to pay about $25 or more per brush. It will seem alot but WELL worth it.
Is there anything stiffer than a brush to use? Something that'd work along the lines of an acrylic marker? I wish there were foam brushes the size and stiffness of a marker tip. I'd have much better results faster.
Or am I going to have to tough it out and learn to use a brush?
God Bless, Ray
Ray
Thats exactly what I'm talking about, thanks! Also, pertaining to using a resist before antique...what all do you coat with the resist? I'm still very new to all of this and the antiquing process intrigues me.
Craig Collier
God Bless, Ray
Like leatheroo mentioned, use a good quality sable brush. They are plenty stiff for this sort of work, and can be had in a very fine point for getting into corners.
I coat the entire piece with the resist. Keeps the antique paste from soaking into the grain of the leather.
