Just started using mine that came in yesterday.
It has many possibilities and for $19.99 on sale right now, it will pay for itself in the quality improvement it helps provide...
I've been looking at it........it makes a lot of sense, especially for us south-paws.....IF the guide can be reversed. Mike
The guide can be removed completely... so you can put it back in however you want.
Glen
You could actually make an extended guide for it adding to the possible uses...
post-15329-013002800 1302793618_thumb.jp
Using it is a breeze, but make sure you have a flat surface your working on. I tired it on my block of cutting board and the edge of the guide followed a groove in the wood.. ACK...
You set the edge of the guide up against your piece after setting the depth you want to cut the groove and pull it around, Doing outer double stitch lines is nice and the lines stay at the same distance apart all along the stitch lines.
Edited by Reaper
They should have had that design first. Now I have both. LOL
Al
What kinda tool is this and is there a pic or vid of this being used?
I was emailed a link for a demo video last week from Tandy, check their website.
Tandy has them on sale for $19.99 right now...
There are things about this one I like better and things about the older/cheaper one I like better.
The old style has the cutter on the arm, which is bad and it has no optional attachments (that I know of).
The new one has a better cutter and comes with a creaser you can use instead to leave nice lines w/out removing leather.
The bad thing about the new one is the curvature of the guide arm. It doesn't ride perfectly straight along the edge of the leather. In fact, when working with 7 oz leather or thinner, I've had it skip up onto the leather, ruining the whole piece of leather. At least with the old one, the barrell that you use as a guide was perfectly straight/perpendicular. It rode better along the edge of thinner leather, IMHO.
Edited by BigK
