Especially Horween Shell Cordovan, which is conditioned a lot. I need strong and flexible glue for watch strap.
The one I was using for other hides simply does not work.
Would be grateful for any hints&links.
Of course the less toxic the better:D
For oily leathers, you need to use an Aliphatic resin or PVA glue made for the shoe industry. I use the Fiebing's Tanner's Bond. Rough up the area before application and let dry a few minutes before sticking together. It is NOT a contact cement so stabilize the joint while it dries.
Art
