when making my holsters, should i glue right to the edge or stop before i get to the stitch line.
i currently stop before the stitch line but think my burnishing suffers some cause the leather can split at the end. on the other hand isnt it harder for my sewing machine to go through the contact cement???
If your sewing machine can bully it's way through 2+ layers of cowhide, a super thin layer of glue isnt going to stand in it's way at all. Glue to the edge and party on! :party26:
I glue to the edge to with no problems.
I'm old enough to know that i don't know everything.
Glueing to the edges is a must. You won't have any problems sewing through the glue line.
I normally glue to the edge; But recently I tried stopping short of the edge because I could see a line after burnishing, where two pieces were joined (which I thought was a result of the glue at the edge). I ended up pulling that work apart due to the gap between the un-glued edges, skivving all the glue off with my head knife and re-glueing all the way to the edge. Unless someone has some secret method that works better- bonding it all the way out is probably the best way to keep the edges tight together (even if it means you end up with a visible division line... maybe that's just me though).
And I agree- if your machine can handle leather it can handle a lil ol' glue layer too.
Nooj
Edited by Nooj
