I don't post many pictures so I figured I put some up, theres a belt, IWB's OWB's and a Mag pouch. The ones that it looks like the stitch lines are farther back from where they should be it's because they are gussetted, the middle layer goes past the stitch line to keep everything tight, I didn't get any pictures of the edges though. The ones with the clips are tuckable IWBs.
Billy
  On 5/19/2011 at 12:34 PM, bitone40 said:
nice work . I really like the belt and the IWB for the LCP. Is that the belt clip from crossbreed ?
Thanks, That one is actually the LC9, it looks just like the LCP only bigger. The clips are from Crossbreed, they recently raised the price quite a bit but I havn't found anything comparable to them that look good with my design and that style of holster is the one that sells the most so I go through quite a bit of them and the Jclips. Probably not near enough to have them made though.
The belt buckle on that belt isn't actually the one that went with that belt, I used it for that picture because it looked good for the picture, it had an antiqued brass roller buckle type, I think they are more secure for concealed carry gun belts then buckles like the S&W one.
yea your right , it is a LC9. I always get them confused , even when I posted it avaliable on my site I typed in LCP and not LC9 .. I still sometimes still write 2010 . Of well and it is still a nice holster , hopefully someday I will get around to trying to make that style ,I really do like it . Have you thought of making your own belt clips from kydex? I heard it is pretty easy , and thats all I know. again hopefully I do plan to try them sometime .
Ben
I could probably make clips, I've played with Kydex a little bit. I would think I'd need some sort of jig to get them perfect each time and I don't have the time to really mess with it now. Someday that might change though, or I might need a different style that I can't buy. The metal ones are really the ones I'd like to find, maybe without the cross for a more discreet look, some people like it, some don't. The ones from Tandy and Springfield function the same but the radius of the metal under the clip doesn't really fit my design and it doesn't look right.
