Members Pele Posted May 22, 2011 Members Report Posted May 22, 2011 A basic request I know, but I have made quiet a few knife sheaths and things out of thicker leather (all hand stitched), but today tried to may myself a watch strap out of some veg tan goat and its all went wrong, i used the saddle stich I normally do and the leather just bunched up :'( . This is pretty much the first time I have tried to do something with thinner leather, I cut out the pieces, glued bits together, put a groove on for stitches, marked them, made the holes for stitching, dyed them with oil based dye, rubbed with carnuba wax, and then started stitching. Am a using the wrong sort of stitch or wrong size of thread? Maybe I was just a bit heavy handed , just not sure so thought I would ask, as it took me all afternoon to make pattern and get to where i did :'( . Many thanks in advance . Quote
Members drphil Posted May 22, 2011 Members Report Posted May 22, 2011 How thin is your leather? I have hand stitched with veg tanned 3-4 oz just fine many times. I never get bunching. What sort of leather are you using? Quote
Members Pele Posted May 22, 2011 Author Members Report Posted May 22, 2011 Its goat, about 1mm thick, sorry dont know how that translates into ounces am afraid. Quote
MADMAX22 Posted May 22, 2011 Report Posted May 22, 2011 You will have to use smaller needles, thinner thread, and a thinner awl. Plus when you are stitching you have to be easy on how tight you pull it. Quote
Members Pele Posted May 23, 2011 Author Members Report Posted May 23, 2011 Ah k, will have a look into what I should be using. Many thanks :D . Quote
Members jimmy eng Posted May 24, 2011 Members Report Posted May 24, 2011 Is the stitching for decoration? I'd use a sewing machine with a leather needle on it if it is. With hand sewing, I get bunching when the thread is too thick for the leather (either too thin or too soft) and I'm pulling too tight. Quote
