1894leverguy
Machine For Rivets And Burrs
I have the opportunity to make a number of leather tool bags for a local company. The sewing part will be relatively simple. Two pieces of leather with a total thickness of ¼” or slightly thicker.
What is needed and would look the best is to have the corners riveted.
While splash rivets would be OK to use, A rivet and burr would have a better finished look on both sides
I was planning on using copper rivets for rust prevention and aesthetic appeal
Is there a pneumatic machine that would that will work instead of the usual method of a hammer and punch?
Is there another rivet system that would work better than the rivet-burr system?
This job may lead to others if everything works out
I'm currently experimenting with a hammer drill and it seems to work ok. The problem I'm having, is the drill that I have is so big and unwieldy. I'm pretty sure if I had a smaller drill, I would be sold. I just put a dimple in the end of a metal rod, put it on the rivet and let it go to town.
Good luck,
Kevin
You can also use tube rivets with caps. I have never used the caps but know several folks that have used them successfully.
Thanks for the replies
Kevin
That sounds like a good idea and a good place to start. It might be a bit difficult to build. A bracket system that holds the hammer drill could be devised or an existing system modified.
Elton
This is what I had originally planned for. Would tube rivets with caps be strong enough?
Would this system work with ¼” material and handle variable thickness.? The short distance is what had me worried and leaning more toward a rivet/burr system
I wonder if anyone utilized Stimpson foot powered machine for solid copper or solid brass rivets.
I am looking at Stimson website and there are no solid rivets there... maybe i am missing something.
http://www.stimpson.com/
They have all kinds of tubular grommets and eyelets but i can not find any solid rivets.
Can you please, if you use a lot of solid rivets share how you set them.
Thank you.
I have the opportunity to make a number of leather tool bags for a local company. The sewing part will be relatively simple. Two pieces of leather with a total thickness of ¼" or slightly thicker.
I see no need to use the copper rivet & burr on material that is only 1/4" or a little over. There is no machine that I know of that will set the burr and then cut and set the copper rivet. If you don't like the finish the splash tool leaves then use the cap for the tubular rivet. Other wise you will need a cutting tool and a hammer to set the burr and rivets. Good luck.
I've had no luck with tubular rivets and caps, about 1/3rd of them come undone.
I have a weaver foot press to put them on.
I just don't trust them.
A jiffy rivet or like would work, or just a copper splash rivet.
