Members ctkroper Posted June 14, 2011 Members Report Posted June 14, 2011 I wanting to make a real heavy duty leather belt! I'm thinkin of a 8 oz or a 10 oz! Wondering wat leather works best? Quote
Contributing Member rdb Posted June 14, 2011 Contributing Member Report Posted June 14, 2011 I'ld go with the 10 oz, or sew 2 7oz together. A long time ago I wrote up a little belt tutorial. Some of it's good, other parts have changed, others may do it altogether different, but here it is. `http://leatherworker.net/forum/index.php?showtopic=4416 Quote Web page Facebook
Members ctkroper Posted June 14, 2011 Author Members Report Posted June 14, 2011 ok thanks ya i been buyin a few belt blanks a tooling them buy they just dont hold up! i think a 10 oz. should hold up good! Quote
Members Glendon Posted June 14, 2011 Members Report Posted June 14, 2011 ok thanks ya i been buyin a few belt blanks a tooling them buy they just dont hold up! i think a 10 oz. should hold up good! What do you mean by hold up? Are they wearing out from use? Stretching when you tool them? Or are they getting damaged from stamping? If your issue is one of the last two problems, then a heaver leather may not be the right fix. Quote
Members cowhide Posted June 14, 2011 Members Report Posted June 14, 2011 I wanting to make a real heavy duty leather belt! I'm thinkin of a 8 oz or a 10 oz! Wondering wat leather works best? question: where are you buying your leather? I have been useing 8/9 or 9/10 oz double shoulders for years and no problems. just buy a top grade leather and not the cheapest. Quote
Members ctkroper Posted June 14, 2011 Author Members Report Posted June 14, 2011 What do you mean by hold up? Are they wearing out from use? Stretching when you tool them? Or are they getting damaged from stamping? If your issue is one of the last two problems, then a heaver leather may not be the right fix. there not stretching and i not having any problems with stamping! but the belt blanks iv made just are to thin by the time a tool them out theres just not much left! i calf rope and do alot of ranch work so im kinda hard on belts! once i save up some money to get a sewing machine ill start sewing some together but a 8 or 10 oz. would prolly work good! Quote
Members ctkroper Posted June 14, 2011 Author Members Report Posted June 14, 2011 question: where are you buying your leather? I have been useing 8/9 or 9/10 oz double shoulders for years and no problems. just buy a top grade leather and not the cheapest. well i was buying the premade belt from tandy but they just dont hold up after tooling them! i think a 8/9 oz or a 9/10 oz. would word good! what do u use for belts? do they last good? Quote
Members cowhide Posted June 14, 2011 Members Report Posted June 14, 2011 well i was buying the premade belt from tandy but they just dont hold up after tooling them! i think a 8/9 oz or a 9/10 oz. would word good! what do u use for belts? do they last good? I do not use Tandy leather. I was useing Siegel of Calif. until they just went out of business. Zack White leather co. has some good db shoulders, Wickett & Craig is some of the best . none of it is cheap.If you buy the double shoulders and strip your own is cheaper in the long run. Quote
Members cowhide Posted June 14, 2011 Members Report Posted June 14, 2011 well i was buying the premade belt from tandy but they just dont hold up after tooling them! i think a 8/9 oz or a 9/10 oz. would word good! what do u use for belts? do they last good? Also do you take the Leather Crafters & Saddle Journal,if not contact at :1-888-289-6409. they are a leather mag. that has some good info and list several dealers. Also try:www.leathercraftersjournal.com Quote
Members ctkroper Posted June 14, 2011 Author Members Report Posted June 14, 2011 I do not use Tandy leather. I was useing Siegel of Calif. until they just went out of business. Zack White leather co. has some good db shoulders, Wickett & Craig is some of the best . none of it is cheap.If you buy the double shoulders and strip your own is cheaper in the long run. oh ok gotcha! ya im new to alot of this! just starting of really! im trying to find good quality leather! ill check of those sites about leather! Quote
