Members mworthan Posted July 29, 2011 Members Report Posted July 29, 2011 Mike, It is the Multi-Purpose (green can) I think. I should be home tonight and if it is any different, I'll repost. Thanks. I'll try to find a supplier local and give it a try. Quote
Members AndyKnight Posted July 29, 2011 Members Report Posted July 29, 2011 I use contact cement from the building supply. both the water based as well as the solvent base. The water base will stick the waxy or oiled latigos/chap leathers. the down side is that it takes longer to dry. I havn't used barge since my boot repairing days ...about 15 years. Quote Andy knight Visit My Website
Members mworthan Posted August 12, 2011 Members Report Posted August 12, 2011 I use contact cement from the building supply. both the water based as well as the solvent base. The water base will stick the waxy or oiled latigos/chap leathers. the down side is that it takes longer to dry. I havn't used barge since my boot repairing days ...about 15 years. Andy, Thanks for the reply. By local building supply, i am asuming that the brand is probably something along the line of Weldwood? I am always a little suspect of the "true"differences in glues as i was about epoxies until I learned that most of them are derivitives of the same Shell product. With that being said, have you seen much difference in performance compared to traditional shoe type glues? I imagine not or you wouldn't use it. Also, any performance differences in water based vs. solvent based? I'm always interested in saving what few brain cells I have left. Switched over to water bourne wood finishes years ago building casework. Can you reveal your brand? Thanks, Mike in Rome Quote
Members mworthan Posted August 24, 2011 Members Report Posted August 24, 2011 I use contact cement from the building supply. both the water based as well as the solvent base. The water base will stick the waxy or oiled latigos/chap leathers. the down side is that it takes longer to dry. I havn't used barge since my boot repairing days ...about 15 years. Andy, Thanks for the reply. By local building supply, i am asuming that the brand is probably something along the line of Weldwood? I am always a little suspect of the "true"differences in glues as i was about epoxies until I learned that most of them are derivitives of the same Shell product. With that being said, have you seen much difference in performance compared to traditional shoe type glues? I imagine not or you wouldn't use it. Also, any performance differences in water based vs. solvent based? I'm always interested in saving what few brain cells I have left. Switched over to water bourne wood finishes years ago building casework. Can you reveal your brand? Thanks, Mike in Rome Quote
Members AndyKnight Posted August 24, 2011 Members Report Posted August 24, 2011 I have used mahy differrent brands and the solvent based ones have all worked quite well. They are all flexible . Weldwood and Lepages as well have worked as well as some store branded. With the water based glues i prefer the white ones as the blue or green tend to show up if there is any extra glue.getting where you don't want it. If you are not sure just buy a quart container first. OWith some glues I will double coat to get a good bond. Andy, Thanks for the reply. By local building supply, i am asuming that the brand is probably something along the line of Weldwood? I am always a little suspect of the "true"differences in glues as i was about epoxies until I learned that most of them are derivitives of the same Shell product. With that being said, have you seen much difference in performance compared to traditional shoe type glues? I imagine not or you wouldn't use it. Also, any performance differences in water based vs. solvent based? I'm always interested in saving what few brain cells I have left. Switched over to water bourne wood finishes years ago building casework. Can you reveal your brand? Thanks, Mike in Rome Quote Andy knight Visit My Website
Members mworthan Posted August 25, 2011 Members Report Posted August 25, 2011 Thanks Andy. I'll try it next go around. Mike Quote
