I recently made a 1/2" wide watch band and when I tried to sew it, I screwed it up. I could not keep the needle in a straight line. And when I made the turn at the top and bottom, it pulled in the corners. they were not square.
I have a Singer 111W155. It is set to sew garments (saving up for a servo motor) but I know how to slow it donw and sew slow with what is in it.
I used #69 thread top and bottom.
Does anyone have any tips for sewing these small items straight? Anyone ever make their own guide for a machine like this?
Tom
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
I always use a stitch grover on both sides on work like this. The needle will take the easy way and the seam will lay protected in the grove. A Singer 29k or a Adler 30 with low foot pressure will do this job just fine. If you do not have one, go bare foot on the clutch pedal and hang on the flywheel. Use a thin needle and thread.
Tom
Tor
I think it's a 20 or 22.. Don't remember. But it is not a leather needle. The only leather needle I have right now is a 23. It's huge for this band
I'm attaching some photos.
Thanks
Tom
post-14889-080638600 1309400076_thumb.jppost-14889-071157500 1309400078_thumb.jppost-14889-097671000 1309400079_thumb.jppost-14889-038573400 1309400081_thumb.jp
Just a suggestion:
After looking at your pics. I'd think a lighter sewing machine; like a Singer 31-15 or 31-20 w/roller foot would be in order. Along with a guide and lighter thread. With a good eye and the original clutch motor on said machine you could get by without a guide; if you were careful.
Simran
Just a suggestion:
Thanks.
On this particular band, the stamping is so close to the edge, a stitch groover would cut too much of the design, which the lady didn't want. I remade the entire thing and used contact cement to secure everything. Then burnished the edges together and so on.
I do have a couple smaller machines in the garage. I' need to dig them out and see if any of them are capable of doing this weight leather.
Later.
Tom
If you want to stitch it you must leave space for the seam and the grovers comes in all sizes.. U use the same as the tread size. I find this method easier than an edge guide on such small items. And looks better to. But a smaller machine will certainly be helpfull.
Thanks.
Later.
Tom
Tor
