Members r lenna Posted July 13, 2011 Members Report Posted July 13, 2011 I've looked around for some info about leaf liners, but I've not found much. l've found many uses for the tool, but I would love to see the way others use it. I have enjoyed all the instruction that I've got from here.Thanks in advance. Rob Quote
Members Reaves Leather Posted July 28, 2011 Members Report Posted July 28, 2011 Leaf liners go on the leaf down the vein. Quote J. Reaves Reaves Leather Smoke and Iron Firefighters MC ReavesLeather.com Facebook
King's X Posted July 28, 2011 Report Posted July 28, 2011 Typical leaf liners come in three different shapes. A regular beveler with lines, a triangle with lines, a pear or shield shape with lines and a semi rectangle with sharp edges. The beveler ones that I own came in a pair. The right and the left angle. The triangle, rectangle and pear or shield shape are just one tool that can be used on both sides. The way that I was taught is that you want to mimic the veins that coming from the stem outwards towards the end of the leaf. The natural process of growth would be from the bottom of the stem where the leaf starts it life upwards toward the tip of the leaf that represent nerves, if you will. The bevelers are easy, but sometimes confusing for some people who are starting out. You determine which tool has the 'right' angle you want and you slip the heel and bevel upwards. Switch bevelers and do the same to the opposite side. The other tools mentioned here are a bit more simple to use. You pick the flat side with the corresponding angle and bevel away upwards. Remember, you want to start out heavy in your pounding at the bottom and fade out as you reach the top. You might want to tilt the tool towards the center stem to avoid making a complete tool mark. I hope I didn't confuse you. I guess I can walk over to my block and take some snap shots for you if I did confuse you? Good luck. Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
