Edge Burnishing
72 members have voted
  1. 1. How do you Burnisher your edges?
    • By Hand with saddle soap
    • By hand with water and Gum Tragacanth
    • By hand with Bees Wax
    • Drill with wood form
    • Drill with fiber form
    • Dremal with wood tool
    • Dremal with fiber tool
    • Home made Burnisher with wood form
    • Home made with Fiber Form
      0
    • Store bought with Wood Form
Utilizing a Harbor Freight drill press like Chris suggests would be a quick and easy way to start burnishing with a minimal investment. But don't forget....you can produce "show quality" edges with a piece of canvas and a little elbow grease. In spite of all the burnishing equipment I have, I often have to burnish by hand or touch up by hand to get the final finish I'm looking for. Another way to go which I've considered messing with is adding arbor extensions to the Craftsman variable speed bench grinder. I have one that I set up for my sharpening wheels and I've always thought it would make a good burnisher. It adjusts from 1750 rpms to 3500 rpms. It's more expensive than the HF drill motor, but you would have the advantage of two burnishing wheels always set up and ready to use. I would put wood wheels on both sides and cover one with canvas....I have yet to see anyone produce better edges than what can be produced by using heavy duct canvas. Just some thoughts.....
Bobby
Bob,
How do you attach your canvas to your burnishing wheels? Obviously the rotating direction is critical, but do you glue the overlap or what?
Edited by evandailey
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
Bob,
I did glue the overlap with Barge initially but it came apart before very long. The thing is though, once the canvas conforms to the wheel and becomes saturated with soap it just sticks to itself. So there was a small amount of flapping, initially. Nothing that was a big deal, just something you noticed and it then it eventually stopped. The whole piece of canvas is just taped on with electrical tape.
I purchased a set of about 2" wool wheels with an arbor at Harbor Freight for about $10.00. I use them in my Shopsmith in the horizontal position with the drill chuck.
Joe
Joefarmer
This is what I use. Spins at 3600 rpms. Pieces are made from stainless steel and were modeled from Weaver's #9 and the wood burnisher off of Weaver's set up. I use it with water and saddle soap (bar). I also use it to smooth the edges of our kydex clips.
This is the result I get (with very little effort):
Edited by K-Man
K-Man....thanks for posting photos of your burnisher and your results. I have seen the stainless burnishers but had no idea how well they performed.
Bobby
Did you make those aluminum burnishers, or did you buy them from somewhere?
Where quality and comfort come together one stitch at a time.
www.gallantgunleather.com
"Pieces are made from stainless steel"
Mike DeLoach
Ok...did you make the "stainless steel" burnishers or purchase them somewhere?
Warpe: I gave a machinist the two pieces of Weaver's tools and they cut them on a lathe. We then removed all the miscellaneous pieces off the shafts of the grinder and mounted the burnishers. We balanced them and they've worked like a champ for the last 5-6 years we've had them.
They look great....I just may have to check on some of the local machine shops and see what deals i can swing.
